un40eh5300f Schematic
  • Sikora
    • Jun 2016
    • 39
    Hello all.
    I am working on this TV and have been trying to figure out why I have no picture but the sound is fine. The back lights are working, so I decided to to the front bezel off to take a look at the boards that are affixed to the panel (not sure what these are called, but it would be nice to know). Anyway after taking a look at these boards it appears that it has some corrosion of sort or a few burnt chips? I need to find out what these are and values to see if I can get replacement ones. I am not even sure how many are suppose to be there. Upon arrival of this unit I heard something loose inside but never seen anything fall out when removing the back of the set. They are very small. I did try to clean one on the right side and it basically completely crumbled. I will try to get the best pics I can, and am just hoping to find a schematic or values and number of whatever these are and try to get replacements. I would hate to part this out for a few dollars in bad parts. Any help would be greatly appreciated. Thanks Jamie Sikora.
    Re: un40eh5300f Schematic
    Those are the tab bonding boards, by any chance the boards are on the bottom edge of the screen? They cannot be easily replaced. You need to clean off the corrosion first, it looks like someone spray the cleaning the liquid on the screen and the liquid got to the boards.
    • CapLeaker
      Leaking Member
      • 8325
      someone washed the LCD screen off?
      • Sikora
        • Jun 2016
        • 39
        Yep they are on the bottom and that makes complete sense now. Would probably be the #1 not to use glass cleaner on these. I would guess I could get some electronics cleaner spray and get off the corrosion, but then I would need to figure out how many and of what is needed to fix. Can't find a schematic anywhere and of coarse Samsung nor J&J will supply that information. Any suggestions on how to obtain. Thanks for the reply.
          You are not going to find the diagram for that board.
          The cleaner should be sprayed on the cloth just enough to damp it, never spray the cleaner directly on the screen.
          • Sikora
            • Jun 2016
            • 39
            I know not to, but I assume that the Lady who's TV it is didn't.
            • Sikora
              • Jun 2016
              • 39
              So about the only thing I could do would be to buy tab bond boards from someone parting out the same TV with a broken screen and desolder those components and resolder them to this one then? You don't think that the diagram would even be in the service manual for this TV then?
              • vinceroger69
                • Mar 2012
                • 6714
                maybe measure the parts if ok that are in the same position on the other end of the board and replace them on the bad side you have nothing to loose by trying
                • Sikora
                  • Jun 2016
                  • 39
                  Ya that would work but unfortunately it looks like it is bad at the exact same spot on both sides. Imagine that. That's almost enough to make me think it is a manufacture defect and not that it got wet at all.
                  • Sikora
                    • Jun 2016
                    • 39
                    So there is no way to contact whoever makes the tab bond boards for Samsung and see if I can get the correct values for the parts that need replaced?
                    • atunguyd
                      Acer x163w Monitor PSU schematic
                      by atunguyd
                      Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
                      The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
                      03-05-2025, 02:08 PM
                    • Lef de art
                      Different capacitors in the sassi and different values in the schematic !
                      by Lef de art
                      Hello guys.
                      Recently i finished my first restoration in a 61 years old tube reel to reel recorder (Geloso G258) .
                      Thanks God the process ended positively and the recorder works again very good.
                      In this process i met a big problem by trying to figure what value in capacitors to use.
                      I say this because all the capacitors excluded the electrolitic had different values from the capacitors in the sassi !!!
                      Not one or two capacitors. It's about 12 capacitors !!!
                      For sure i have the correct schematic.
                      At the end i have used...
                      11-03-2019, 04:22 PM
                    • rashidjafar
                      Nvidia GTS 250M Laptop graphics - Inductor and Capacitor values
                      by rashidjafar
                      I am looking for capacitor & Inductor values for my TOSHIBA Qosmio X500-110 - mobile graphics - Nvidia GTS 250M Laptop.
                      Values for :-
                      PC43 : Capacitor [3x1.5mm]
                      PL7 : Inductor [2x1mm]
                      PC39 : Capacitor [1x0.5mm]
                      Any ideas would be appreciated.
                      I can get Capacitor values from nearby components but wanted to know the max ratings also I dont have equipment to measure inductors....
                      08-07-2025, 05:10 PM
                    • Thetechdude
                      MSI Ventus RTX 4080 16G Broadview schematic needed
                      by Thetechdude
                      Hi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
                      I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
                      Thanks.
                      07-15-2025, 11:15 AM
                    • ianpoultonknights
                      Zenbook Flip 15 UX562AI schematic
                      by ianpoultonknights
                      Had one of these come in for repair with a blown battery and a WiFi issue, battery has been replaced with genuine battery (twice) and won't take a charge works fine on AC, WiFi issue gone away. Looking for a schematic so I can trace the charger circuit UM562F is only one I can find, this is the 562AI model.Had a unit come in for repair — 562AI model — with a blown battery and WiFi issue. WiFi fault has cleared, but battery won’t charge despite replacing it twice with genuine parts. Device operates fine on AC power. Suspect charger circuit fault. Only schematic I’ve found so far is for...
                      06-26-2025, 02:41 PM
