MSI Ventus RTX 4080 16G Broadview schematic needed
This topic has been answered.
  • Thetechdude
    • Jul 2025
    • 5
    Hi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
    I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
    Thanks.
  • Answer selected by Thetechdude at 10-03-2025, 05:10 AM.
    Thetechdude
    • Jul 2025
    • 5
    Semi-resolved
    Swapping core on a new PCB was the fix for this one. Unfortunately not sure what the actual issue was beyond that
    • duck.dodgers
      • Mar 2021
      • Slovakia
      HI,
      I don't have schematic, but your case seems relatively simple. First of all check resistance on this 1V8 rail, if it isn't overloaded. If not, check 1V8 driver voltages (should be 5V VCC and 12V VIN) - if proper voltages are present, replace the driver. If it still won't help, the culprit will be resistor divider on FB circuit. There are tons of schematis and boardviews of RTX20xx/30xx/40xx series cards here on Badcaps, I'm sure you'll find at least one with exactly the same 1V8 DC/DC converter as yours.
      Regards
      • duck.dodgers
        • Mar 2021
        • Slovakia
        Hint - if your 1V8 driver is GS9216/GS9219/AOZ2261 (I bet it's one of them), check GV-N3080EAGLE schematic and corresponding BV for instance
        • duck.dodgers
          • Mar 2021
          • Slovakia
          Sorry, but I've just realized I could have misled you. It's because the best card I had for repair so far was RTX 3090Ti and I haven't had a chance to put my hands on any 40xx card yet. Looking at some RTX4080/4090 schematics I've noticed a slight change, namely for Ada Lovelace architecture proper voltage is 1.2V instead of 1.8V. I don't know how accurate your multimeter is and what range you've chosen for measurement, so 1.1V may be perfectly fine and the problem lies somewhere else.
          In that case I would suggest to check power sequence, especially if 1V8/1V2 controller is setting PS_GA1V8_NP1V2_PGOOD signal (pin #1 if it's GS9216/GS9219/AOZ6621) and if so, then in next step if NVVDD controller is powered and enabled (if it's uP9512 then should be 5V at pin #12 and pin #36 has to be in logic high state)
          • ro.man
            • Mar 2015
            • 16
            If any one still needs it - this mixture could help...
            • Thetechdude
              • Jul 2025
              • 5
              Semi-resolved
              • new
                Collection of Laptop Motherboard Schematic and Boardviews
                by new
                List of Pack :
                01- Acer Aspire 3 A315-23G Quanta Z8E (DA0Z8EMB8C0) Schematic & Boardview
                02- Acer Aspire 3 A315-33 DH5JL Compal LA-F943P r1.0 Schematic
                03- Acer Aspire 5 A515-52K Compal LA-H441P Schematic
                04- Acer Chromebook Spin 311 CP311-2H ZBA ZBB DA0ZBAMB6A0 Schematic
                05- Acer Chromebook Spin 311 CP311-3H ZDE DA0ZDEMB8B0 Schematic
                06- Acer ConceptD 9 CN917-71 Compal FH79F LA-G162P Schematic
                07- Acer Spin 3 SP314-53GN Pegatron DL4FA Dolly Schematic
                08- Acer Swift 3 SF315-41G...
                02-18-2026, 01:06 AM
              • Boardview and Schematic Bot
                NVIDIA GeForce RTX 4080 (RTX4080) Schematic & Board View
                The GeForce RTX 4080 is an enthusiast-class graphics card by NVIDIA, launched on September 20th, 2022. Built on the 5 nm process, and based on the AD103 graphics processor, in its AD103-300-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 4080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The AD103 graphics processor is a large chip with a die area of 379 mm²...
                10-02-2024, 08:57 AM
              • huzo
                AI Service Engineer – Laptop Schematic Analysis & Guided Board Diagnostics [BETA]
                by huzo
                I've been working on a small Windows tool for laptop motherboard diagnostics and I'd like to share the first public beta with the community.
                The project is called:
                AI Service Engineer
                The idea came from a very practical problem during board repair.
                When troubleshooting a motherboard, a lot of time can be spent jumping between schematic pages trying to find the next power rail, enable signal, power-good signal or reset signal that should be checked.
                I wanted to build something that could help guide that process....
                08-31-2026, 02:13 PM
              • achraf814
                Asus UX581GV schematic needed
                by achraf814
                UX581GV schematic needed — looking for PTR9004 value on P_CHG_CMPIN / P_CHG_REGN nets , what component is it ? Thank you...
                06-22-2026, 05:45 PM
              • Msc Repairs
                PS5 EDM-010 Schematic & Service Manual Repair Advice Needed
                by Msc Repairs
                I'm currently teaching myself board repair and schematic/boardview analysis, and I'm hoping someone can point me in the right direction.
                I can generally follow schematics and boardviews when the net names match and are clearly labelled. However, on the board I'm working on, all of the nets are named things like NET1, NET2, NET10000, etc., rather than having meaningful names for the power rails and signals.
                I'm struggling to understand how experienced technicians identify and trace power rails in this situation. Are there any methods, techniques,...
                06-05-2026, 01:43 AM
