Any neat tips or tricks for finding cracked LCD's when the backlights wont turn on.
  • sattech200
    • Aug 2012
    • 59
    Any neat tips or tricks for finding cracked LCD's when the backlights wont turn on/wont power up/power isnt available.
    Ive been trying to visually inspect the screens closely under good lighting, at different angels, using a flashlight, but still seem to miss some that are cracked.
    Just wondering if anyone has any neat tricks or tips to detect cracked or damaged LCD's when the units wont power up or lets say when power isnt available.
  • ozzy214
    • Nov 2013
    • 319
    • usa
    Re: Any neat tips or tricks for finding cracked LCD's when the backlights wont turn o
    If its lcd, you can buy a inverter and power it up.
    http://www.ebay.com/itm/4-Lamp-Backl...YAAOSwX~dWqcM8
    There is many more to choose from. Or if the powerboard is working just jump pson to 5v ref and bl on to 5v with mainboard disconnected. That should kick them on!
    • mrblobby
      • Jul 2013
      • 22
      • uk
      Viewing through a polarizing filter and bright light may help..
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Use a powerful torch or hold the Tv in an area with bright oight and you will be able to see any fractures in the glass.
        • ozzy214
          • Nov 2013
          • 319
          • usa
          Lol you brits are funny calling a flashlight a torch. I can just picture op like a caveman holding a stick wrapped in oil on fire looking at the tv...lololol.
          Sorry had to. I was like wtf till I realized you guys dont call them a flashlight!
          • ozzy214
            • Nov 2013
            • 319
            • usa
            Yes a high power led flashlight will usually show all cracks.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Lol we do it our way over here
              • comptek
                • Aug 2013
                • 606
                • uk
                bright sunlight and funny looking lines try rubbing them as people dont seem to cean tvs screens anymore
                • Prott
                  Soldering flex cable - tips & tricks
                  by Prott
                  Hello fellow badcappers,
                  I have to solder a MacBook (A1708) screen flex - one of the two data flexes got slightly torn (2 broken traces). I've seen some videos on youtube where people scrub the coating and then simply apply flux and solder to the exposed copper traces (and then run a jumper wire). However no matter what I try the copper does not take the solder at all - the more flux I add the more it actually stays only on the iron itself.
                  I am practicing on a spare flex cable and it's gettiing quite annoying - to a point I am actually thinking I have to be doing something...
                  10-04-2023, 06:25 AM
                • SapientLion
                  2004/05 AGP GPUs: Repair Tips and Tricks
                  by SapientLion
                  Hello, everyone!
                  This is my first actual post on this forum. I don't know anyone here nor have any knowledge on proper etiquette that is supposed to be applied here... So, bear with me and my mistakes. I'll try my best. Regardless, here's my story.
                  A few days ago, i discovered and managed to purchase two AGP x8 GPUs (ASUS Extreme N6600 [NVIDIA GeForce 6600] and ASUS AX1650PRO AGP [ATI Radeon X1650 Pro] ), from a trusted seller, for dirt cheap, which were released way back in 2004/05. They were primarily used for graphics design and 3D modelling. As far as know,...
                  06-28-2023, 05:35 PM
                • ronaldopdias
                  14" MacBook LCDs - has Apple re-introduced a new serialisation type?
                  by ronaldopdias
                  Since about a month or two ago, we've observed a new type of 'serialisation' on the LCDs and we're just curious whether anyone has seen this
                  • New LCDs straight from the factory (not programmed)- if the Mac is restarted or switched on from a cold boot, you must close the lid, then open it again (so two cycles of opening and closing the screen) in order to get display.
                  • Transplant the IC onto another screen:
                    • If the model and revision match exactly then it will perform as normal
                    • If the manufacturer matches exactly BUT its a different revision, the colours are mostly in
                  06-28-2025, 09:56 AM
                • estabilito
                  Tips geting oxidized when using wick
                  by estabilito
                  Hi, i have weird problem - when i'm using soldering wick to clean BGA balls under CPU or PCH on motherboard my tips(different types) getting oxidized very fast and lost all power.
                  i Was trying different types of wick, flux - no difference. I can't even clean one full socket and i need to use deoxidizer in half-time.
                  Temperature: 350-365celsius
                  station: jbc cd-2bqe
                  Wick: edsyn
                  flux: warton hf rework jelly
                  Do you have any tips?...
                  04-12-2025, 11:55 AM
                • sattech200
                  Tips or tricks to identify cracked LCD panels on dead units?
                  by sattech200
                  Anyone have any tips on spotting cracked LCD panels on units that wont power up?
                  I recently bought a lot of a couple dozen flat screens and discovered there were more cracked displays then I was originally able to see, which is ok, I am still money ahead.
                  Now I have a handful of units sitting here that are dead due to power supply or mainboard issues. Starting to second guess myself weather to sink the money into them for replacement parts only to find out I have more cracked panels. ...
                  08-23-2016, 02:13 AM
