westinghouse DWM55F2Y1 will not turn on
  • Jp06
    • May 2016
    • 127
    • Usa
    Hello everyone please help me troubleshoot this tv. It has no stand by light thus it will not power on... all the sudden. Here are some pictures. I assume the problem lie somewhere on the power supply board (PSB).. So here are some close up pictures of it. The fuse is good and but i got zero reading at those areas circled in red. Thank you so much for any helps/suggestions.
    Re: westinghouse DWM55F2Y1 will not turn on
    If the main fuse is OK then you need to find out first if you do have DCV between the two legs of the main filter cap in the primary side of the power supply board, it should be around 160 Vdc.
    • Jp06
      • May 2016
      • 127
      • Usa
      Hi Budm when you said that do you mean this.. (circled in red) Where the power cord come in?
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        No, it's the capacitor with 2011/65/EU on it you need to measure....with care (160V)
        • Moreno83
          • Jun 2014
          • 2008
          • The Netherlands
          Yes , above that is a fuse. MEasure it for continuity
          • cliff_hootarski
            • Jul 2006
            • 411
            disregard
            • Jp06
              • May 2016
              • 127
              • Usa
              Hi dick_barton, thanks.. it reads at 159.9 DCV
              Hi moreno, fuse is good
              • Jp06
                • May 2016
                • 127
                • Usa
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  So you have rectified AC which is good. What is the number on the 8 leg IC labelled IC1?
                  • Jp06
                    • May 2016
                    • 127
                    • Usa
                    Hi Dick_barton excuse my lack of knowledge with these board but i can't seem to find anything that label IC1 .. there is EC1 which is that big cap with 2011/65/EU on it which you asked to measure.
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      I've circled it in red. By the way what voltage is written on that Cap EC1
                      • Jp06
                        • May 2016
                        • 127
                        • Usa
                        Thanks so much for the quick reply dick_barton but i have to head to work now. Shall get those done later tonight
                        • Jp06
                          • May 2016
                          • 127
                          • Usa
                          good evening Dick_barton here is the readings for IC1, please refer to diagram... and the voltage written on that Cap EC1 is 100uF 450V
                            So what is the P/N of that IC 1?
                            What you show on the measurement does not mean anything unless we know what the pin out of the IC is.
                            • Jp06
                              • May 2016
                              • 127
                              • Usa
                              Hi Budm by P/N you mean the number written on that IC1? Here is a close up of the it.. If you rotate it right side up.. it's the same arrrangement as the diagram of where i took the readings.
                                NCP1607 is the PFC Controller IC.
                                https://cdn.badcaps-static.com/pdfs/...a1d57aebe2.pdf
                                  Try heating up the startup/running caps with hair dryer to see if you will get STBY Voltage, you need to also check the diodes in the cold side.
                                  • Jp06
                                    • May 2016
                                    • 127
                                    • Usa
                                    So Budm i got zero for the one under the cover and 208 for the 2 diodes. (it's BR560 mojsmc) Heating the startup/running caps, i still get no STBY voltage
                                      What do mean by 0 Volt?
                                      What did you set the meter to?
                                      You can test using Ohm mode in 200 Ohm scale to see if the diodes show low Ohm in both direction, no power to the board of course.
                                        BTW, the diode on the heat sink is common cathode, the two out side pins are tied together, the middle pin is the cathode so you can test the resistance between the outer pin and the center pin.
                                        You might as well try replacing those tow startup/running caps to see what happen.
                                        You also need to get the PN of that tiny SMPS IC so you can find out if it is getting the Vic to run the IC or not.
                                        • pajdek
                                          Lenovo Y700-17ISK turn on and off
                                          by pajdek
                                          Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                          09-20-2023, 02:49 AM
                                        • RdeveLabs
                                          MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                          by RdeveLabs
                                          To all the members here...
                                          Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                          So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                          05-05-2025, 04:59 AM
                                        • robante15
                                          Acer Aspire 4520 won't turn on after reboot
                                          by robante15
                                          Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                                          It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                                          The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                                          If I remove the...
                                          04-06-2024, 06:50 PM
                                        • masoksian
                                          Dell latitude e7470 not turn on .power buton on off and Run Power problem
                                          by masoksian
                                          I am dealing with the problem of turning on and off my Dell e7470 notebook.
                                          The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                                          The system does not turn on, there is no post.
                                          I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                                          The problem continues in the same way.
                                          I tried to turn on the Fn key, nothing came to the screen....
                                          02-15-2025, 12:08 PM
                                        • dqtech
                                          lenovo x240 nm-a091 wont turn on
                                          by dqtech
                                          i got this laptop with no power issue....i flashed the bios and laptop can turn on and use normally....but when i shut it down and rest for few minute (2-3 minutes), it wont turn on....i have to flash bios again...any idea what is the problem?...when i shutdown and suddenly press power button to turn on, it will turn on normally....problem happen when i rest the laptop 2-3 minutes after shutdown, it will not turn on....i need to flash bios again
                                          board number VIUX1 NM-A091 REV:1.0...
                                          02-07-2024, 01:57 AM
