LG 42LH3000 Tcon question
  • mattheweveringham
    • Jul 2016
    • 8
    Hi, i have bleaching (fading to white after a few mins) and from everything I've learned it's likely a t-con as15 chip issue (at least it seems that's what i should replace first)
    I was wondering about a section of the model numbers and if anyone has suggestions for a decent supplier, even a decent chinese supplier.
    My numbers are as follows.
    42T06-C03 - 55.42T06.C16 - T420HW04 V0 CTRL BD
    I was wondering how important is the c16 part and what does it mean? I got the impression it might be a software thing as lts of suppliers don't seem to issue that part, especially the chinese manufacturers like taishun on ebay.
    Does it matter that much and if so how come lots of manufacturers don't list them? Also, what does the c03 part mean?
    Would greatly appreciate any help on this as i don't have the tools to solder a new chip but ensuring i get the right t-con or at least a good one is proving difficult.
    Thanks guys.
    Last edited by mattheweveringham; 07-16-2016, 11:52 AM. Reason: made a mistake sorry, i meant the meaning behind the c16 part and the 013 part, NOT c03.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: LG 42LH3000 Tcon question
    Have you images of the board please ?
    • mattheweveringham
      • Jul 2016
      • 8
      Are these ok? I know one of the chips is hard to see but i took these a while ago, do you want me to go take some more?
      • mattheweveringham
        • Jul 2016
        • 8
        The serial is on the board is 42T06-C03 T420HW04 V0 CTRL BD
        serial on label is UT 55.42T06.C16 - 013. Was just wondering about the c16 and the 013.
        • mattheweveringham
          • Jul 2016
          • 8
          I guess i managed to actually stump the board. I guess c16 is a revision and not that important and the 013 is just a batch number or something.
          Does anybody at least know what other tcons are compatible with an lg42lh3000?
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            If you are looking for a board replacement I think the 42T06-C03 number is the one to use to make your order.
            • flocko
              • Nov 2012
              • 1121
              The part number of this board is shown on the white bar code sticker 5542T06C16 with board type being T420HW04 VO (Sticker part number should match for it to work correctly)Substitute Part(s):
              55.42T06.C19 55.42T06.C09 55.42T06.C15 55.42T06.C20 55.42T06.C14 55.42T06.C13 55.42T06.C12 55.42T06.C17
              • Moreno83
                • Jun 2014
                • 2008
                • The Netherlands
                As flocko says.
                If you want a cheap fix then replace the AS15 chip. Don't forget to check if it's a F / G chip.
                • mattheweveringham
                  • Jul 2016
                  • 8
                  Thank you all. I managed to find a C16 so i got that. Very last question is does anyone know why chinese manufacturers of these boards don't list the C16/C17/C18 etc part?
                  They all say 42T06-C03 and T420HW04 V0 CTRL BD but never list the C16 or substitute parts. Does anybody know why??
                  Thanks for the information and i won't bother anyone with anymore questions. I was just curious if one of those chinese boards would work with my TV without any mention of the C16 part. Just seems kind of weird and can't figure out if that stands for something to do with the software like a revision or something.
                  Cheers guys.
                    From shopjimmy:
                    SKU: sj-55.42T06.C16
                    Warranty: 180-Day Warranty
                    Part Type: T-Con Board, LCD Controller, Control Board, CTRL Board, Timing Control
                    Part Number: 55.42T06.C16
                    Part Usage: LCD
                    Board Number(s): 42T06-C03, T420HW04 V0, 5542T06C16
                    Substitute Parts: 55.42T06.C19, 55.42T06.C09, 55.42T06.C15, 55.42T06.C20, 55.42T06.C14, 55.42T06.C13, 55.42T06.C12, 55.42T06.C17
                    Panel Sticker Number: T420HW04 V.0
                    Panel Manufacturer: AU Optronics
                    Notes, Comments & Additional Information: ShopJimmy recommends ordering by part number whenever possible. Often times there are TV models that use more than one set of parts and/or panels.
                    TV Brands: Lg, Sanyo, Viore, Vizio
                    Important Message: Part number can be found on the sticker.
                    • figurehead21
                      • Jul 2016
                      • 6
                      the different C1X number is going to be a version of eeprom on the TCON, it wont hurt anything to put a 16 or whatever of that series in, it will distort the picture if wrong
                      • mattheweveringham
                        • Jul 2016
                        • 8
                        Thanks guys, i managed to find a part with the correct eeprom number so all is good. At least i know i can potentially try a chinese tcon without having to worry too much about that part.
                        • kca
                          by kca
                          Hello all ~
                          08-31-2025, 06:38 AM
                        • x_orange90_x
                          TCL 50S535 bad tcon or panel issue?
                          by x_orange90_x
                          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                          03-29-2025, 11:02 PM
                        • advant
                          by advant
                          02-03-2020, 12:25 AM
                        • Hakuu
                          by Hakuu
                          Hi There,
                          More Details
                          TV Model - LG OLED77G1PUA
                          07-12-2023, 02:37 PM
                        • netgearnetgear
                          TCL 43S423 TCON OR PANEL FAULTY???
                          by netgearnetgear
                          Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                          08-20-2025, 06:04 PM
