LG 70LB7100 no backlight after 2-5 min
  • DXseekerMO
    • Feb 2018
    • 1119
    • US
    #41
    Re: LG 70LB7100 no backlight after 2-5 min
    I think there are 8 rows of LED strips in this TV. There's 24 total pieces to the LED array divided by three in one row equals 8 rows total
    They call me......."threadkiller"
    • zomi
      • Nov 2011
      • 511
      #42
      https://www.aliexpress.com/item/New-...875904086.html
      I would just get that
      • DXseekerMO
        • Feb 2018
        • 1119
        • US
        #43
        Originally posted by zomi
        That is nearly half of what ShopJimmy wants for a set of those, great find! My only question would be the quality of the strips, but if they are up to par then that is a great deal!
        • floki
          • Nov 2018
          • 12
          Thank you so much!
          • floki
            • Nov 2018
            • 12
            Gotcha. I'll probably go ahead and take the TV apart first to verify before ordering. I got the TV for free from a buddy, so spending a $100 or so to possibly repair is a risk i'm willing to take.
            • DXseekerMO
              • Feb 2018
              • 1119
              • US
              #46
              Have you considered getting a practice TV?
              • bult
                • Jun 2016
                • Sweden
                #47
                I ended upp taking the panel off. The problem was with some of the LED´s. Some were shorted others were open. It was a pretty easy job but time consuming since I ended up testing every LED separately. Gluing the lenses back took some time... And yes, my garage is a mess...
                • shafercomputers
                  • May 2017
                  • 4
                  Just some info from a tv repair man. I've worked on this set once before issue was intermittent loss of backlights(had bad backlights) no surprise with tvs nowadays but after replacing all the backlights it still had the same issue. Almost never have a set with backlight issues that weren't in the strips or the power supply. Replaced the power supply as well same issues. Customer was getting impatient by now so we called it quits. So I ended up selling the circuit boards on Ebay. After selling the Main board got a message from the buyer saying that their set that was having different issues all together now had a new symptom.. Intermittent loss of backlights. So apparently the main board on this set has a lot of control over backlight function along with the set having just general led failure as well. Just had the same model brought in today too with same symptoms I'll give ya an update on what I find.
                  • shafercomputers
                    • May 2017
                    • 4
                    Went ahead and replaced Main Board as it's main IC was running 140F-150F. Also backlights tested fine on this specific set. Since this set has no ventilation I installed a pc fan and drilled some holes for air intake and out. Main IC on new Main Board was running at around 125-130F which is around normal. Set has been back to customer for almost a month now with no issues. So to summarize this set's main board seems to overheat and turn the backlights off at least on the past two I've worked on.
                    • KPGipson
                      • Mar 2023
                      Hi- I have a 70LB7100 with backlight issues. I received a used unit and it would play for a couple of hours then the backlight would turn off (brightness at 100%). There was still sound and video. If I turned the TV off then back on it would come on and the backlight would turn on for a couple of minutes then off. If I turned the brightness down to 80% the backlight would stay on for much longer.
                      Sounds like a thermal issue.
                      Then I removed the back cover of the TV and turned it on. The backlight seemed to go off if I tried to lift the panel or move it a small amount. Now, the backlight goes off ~ 7 secs after turning the set on and the red LED on the power supply blinks 4 times repetitively.
                      Now since the backlight is only on few a few seconds I can't turn the brightness down or do a factory reset. When the TV was working the display looked great but I did not test it with a full white screen to see if any LEDs are dim or completely out.
                      Any suggestions? Thanks.
                      • KPGipson
                        • Mar 2023
                        Another note: I disconnected the LED cables from the power supply and powered the TV up. The red LED did not come on. I turned the unit off, reconnected the cables, and powered it up. It acted as before with the red LED blinking.
                        • b0ba
                          • Mar 2018
                          • 13
                          • Ukraine
                          #52
                          -- del --
                            • 12317
                            • U.S.
                            #53
                            This right here is most likely pointing to bad backlights: Quote " If I turned the brightness down to 80% the backlight would stay on for much longer."
                            • Mgiffune
                              by Mgiffune
                              06-09-2024, 10:28 AM
                            • triplefour
                              by triplefour
                              09-13-2023, 10:43 PM
                            • DanPoka
                              Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                              by DanPoka
                              I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                              Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                              This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                              02-15-2025, 05:05 AM
                            • Comp_Pro
                              No Backlight Macbook A1990 820-01041
                              by Comp_Pro
                              Hello all,
                              Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                              Tests performed:
                              There is no backlight even with a good screen.
                              Backlight IC is receiving the correct support voltages.
                              Fuse F8400 ok
                              Current sense resistor R8400 ok
                              Backlight IC is receiving 3.3V on enable pin.
                              Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                              Backlight IC receiving 5V from PP5V_G3S
                              Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                              I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                              05-06-2024, 10:23 PM
                            • cheebster
                              iPad Pro 12.9 5th Gen Backlight Issue
                              by cheebster
                              Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                              Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                              Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                              The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                              Anyone...
                              05-20-2025, 09:17 AM
