LG32LB561V Black Screen with sound
    My mate has asked me to look at this for him as he has some daft notion that I actually know what I'm doing. So to help me impress him I thought I'd turn to you guys
    So the problem is the display is completely black, but the TV is switching channels as you can hear the audio of the different programs.
    Below are pictures of the 2 PCBs inside the set, the T-Con board is covered by a plate, which it seems to be attached to somehow.
    Any help appreciated.
    Re: LG32LB561V Black Screen with sound
    Please show the pictures of the whole backside of the TV so we see all the boards including the T-CON board.
      Thanks for the rapid response, I'll upload them shortly.
        Do you get backlight ?
          The screen is completely black, no flicker or anything.
          Thanks.
            New set of pictures of PCBs, I can't work out how to get the metal bracket seperated from the T-Con board. Do they solder them to the PCB, there appears to be 2 contact points connecting the metal shield to the PCB.
            A little more info that might help. When the set is powered up, the red standby button comes on, when a channel is selected this slowly flashes red and then goes off. This is with no input connected though as I can't hook it up to anything at the moment.
            Have now added the T-Con board picture
              Ok if you shine a torch on the screen can you see an image faintly ?
                Add a photo and someone can advise you how to remove it
                  Just hooked t up to the Sky box and could just make out the Pause symbol in the bottom left corner, couldn't really see much else.
                    Dont do that yet we need to know if the Lcd is working but not backlit. If it is the Tcon does not need to be touched.
                      Fathomed it out and added the picture to previous post.
                        Ooops, too late. But all connected back up as it was
                          Ok well the Tcon and Lcd is fine. Your backlight is not working here. I will link my video on how to test it and another for Lg Led Tv's you probably have a failed Led in the screen.
                            Thanks for that, just on a side note, is this an expensive/tricky fix. As it isn't my set is the cost of repair worth the hassle ?
                            You haven't added the link
                            Thanks for the help.
                              Link to my Led backlight repair video:
                              https://m.youtube.com/watch?v=RxwdC7V5Ue0
                              Link to Norcal's Lg Tv repair video:
                              https://m.youtube.com/watch?v=Bf5T2wwtydY
                                Also not too easy and you have to be VERY careful with the Lcd screen. You need to learn how to test the driver first watch norcals video on how to do that. The drive voltage for this set is roughly 80v start up then 70v running if it starts high then goes low you have a failed led.
                                  If that's the case I think I'll pass it back to the owner, as this was only supposed to be a quick look as a favour and see if there is anything easy to fix. I'd rather not cause more damage to the set.
                                  Thanks for the help though it was really appreciated.
                                    Possibly, too bad your so far from me could have offered to fix it. No worries glad to help anyway
