Sharp LC-42SB48UT-a no standby voltage
  • AcGeorgiegirl
    • Jun 2013
    • 202
    I've looked the psb over, and find no obvious caps issues, and the 2 fuses are good. I thought of testing the ac input to start with, but haven't found how to do this. My wall outlet reads fine. Otherwise, I'm assuming I'd need to dive into testing individual components? Diodes, transistors, resistors, etc....but I can't make sense of the schematic in the service manual I've found(well, I wouldn't be able to with ANY schematic, for the most part!). Also, my service manual actually has a different psb shown for my tv. It's not even close to what mine looks like.(and, yes, I confirm it is the correct manual- but not the paper one-one I downloaded).
    I am ok in testing the components, as far as that goes...but don't know what the numbers mean, if I don't have their correct voltages, right?
    Re: Sharp LC-42SB48UT-a no standby voltage
    Check the DCV between the two legs of the big main filter cap in the primary side to see if you have 160~165VDC on it or not first.
    • CapLeaker
      Leaking Member
      • 8113
      Post the DC voltages measured on the connector top right including the pin out name.
      • AcGeorgiegirl
        • Jun 2013
        • 202
        I'm assuming I'd have to completely remove the cap from circuit first, right? I don't have an esr meter, but do have one with ohm's.
        • dick_barton
          • Aug 2015
          • 6642
          • Wales
          Put your meter on DC volts and place one of the meter probes on each of the legs of C907 and power the set up. What reading do you get.
          • AcGeorgiegirl
            • Jun 2013
            • 202
            I get 2 with meter set at 500v. This is with the set plugged into outlet.
            • AcGeorgiegirl
              • Jun 2013
              • 202
              Sorry, I accidentally replied directly to another posting...the meter reads 2 with it set at 500v. Tv plugged in, but, of course, not powered on.
                Meter set to DCV? If that is the case, then you need to check the main AC fuses (you have two main AC fuses), the bridge rectifier.
                • AcGeorgiegirl
                  • Jun 2013
                  • 202
                  No voltages on any of the pins.
                  • AcGeorgiegirl
                    • Jun 2013
                    • 202
                    Each fuse reads 0.2 with an ohm's 200 test.
                    • dick_barton
                      • Aug 2015
                      • 6642
                      • Wales
                      You need to switch on the set to measure this voltage.
                      • AcGeorgiegirl
                        • Jun 2013
                        • 202
                        I'm confused, sorry....there's no standby voltage, and it won't power up.
                          So the meter is set to dcv when you check the Voltage between the two legs of the main filter cap C907?
                          "Sorry, I accidentally replied directly to another posting...the meter reads 2 with it set at 500v. Tv plugged in, but, of course, not powered on."
                          You need to find out if you are getting 120VAC between the two inner legs of the bridge rectifier BD901.
                          You MUST be real careful since you are working in the HOT DEADLY side of the circuit.
                          Sharp ADTVA2415SA4 Power Supply for LC-42SB48UT
                          Pictures provided by shopjimmy.
                          • AcGeorgiegirl
                            • Jun 2013
                            • 202
                            Can someone help me identify what this board's bridge rectifier is? I see nothing that looks like the ones I've seen before. I'll test it, as suggested, if I can find it!
                              Look at the designator a BD901 as printed on the board.https://www.badcaps.net/forum/attach...2&d=1466534208
                              Bottom left corner of the board.
                              You just need to find out if you do have 120VAC feeding the bridge two inner pins. See post #13.
                              • dick_barton
                                • Aug 2015
                                • 6642
                                • Wales
                                The bridge rectifier is BD901
                                • AcGeorgiegirl
                                  • Jun 2013
                                  • 202
                                  Oh, boy. It has apparently been de-soldered by someone...the pins are staying put, but solder is missing on the ends of the pins. I can't remember if maybe I'm the one who did this, planning to pull the part and test it?! I have no idea. Anyway, my question is..can I test the pins as it sits, or do I need to add solder to the pins' ends?....(would it not read true unless it's in circuit)?
                                  • dick_barton
                                    • Aug 2015
                                    • 6642
                                    • Wales
                                    I would solder it back in neatly and then do the check.
                                    • AcGeorgiegirl
                                      • Jun 2013
                                      • 202
                                      I went ahead and tested it as is, to begin with. With the + probe on the - pin, the ac's read 514 & 521. With - probe on the - pin, the reading doesn't change. I'll now go ahead and solder the pins to the board and re-test.
                                      • dick_barton
                                        • Aug 2015
                                        • 6642
                                        • Wales
                                        Put the red lead on "+" and the black lead on "-" and the meter to DC volts.
                                        • x_orange90_x
                                          Samsung UN55KU6300F no standby voltage
                                          by x_orange90_x
                                          I have no standby indicator light and no light on the optical port. I checked the standby voltage on the two mosfets in the top left and they both read 30mV. I checked the fuse and it has continuity. I also checked the voltage on the two large 450v caps they both read 153v. All of these voltages are the same with and without the main board connected as well as with backlights connected/disconnected.
                                          Nothing looks obvious like a burned ceramic disc cap or bulged electrolytic. No burned resistors, diodes, or anything like that....
                                          05-21-2025, 09:59 PM
                                        • Bad_IC
                                          Philips TV 37pfl5604h/12 no standby voltage
                                          by Bad_IC
                                          I have a problem with this TV, the standby voltage is not present. I have checked the components around the IC fsq510's area and they seem to work, also replaced this IC but the problem persists.
                                          These are the voltages in some pins of IC fsq510:
                                          Vcc=18v
                                          D=320v
                                          Vstr=154v
                                          Unfortunately, I couldn't find the schematic
                                          What else could I check?
                                          Is it possible to provide standby voltage from an external source to allow the TV to turn on?
                                          Thank you​...
                                          11-08-2024, 01:07 PM
                                        • brock-s
                                          Asus GL503GE 3.3 standby voltage low
                                          by brock-s
                                          An Asus GL503GE laptop arrived that had had a screw dropped on the motherboard while the battery was connected. This resulted in a physical damage to the 3.3v / 5v voltage controller RT6575DGQW (pu28 on schematic, page 40). Additionally, the trace to pin 12 (VIN 19v supply) was burnt.
                                          Replaced the RT6575DGQW with a new one, repaired the damaged trace. Only getting 0.7V instead of the expected 3.3v standby voltage (3V_S5 on schematic).
                                          Replaced the AON7408 PQ60 mosfet from a donor board as resistance was low on the gate (I did not write this value down, as I optimistically...
                                          07-13-2023, 03:43 PM
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
                                        • Ritchie_Uk
                                          Sharp 32BC2K0 Service Manual of Fix Please?
                                          by Ritchie_Uk
                                          Hi Folks
                                          I am searching for a Sharp 32BC2K0 Service Manual
                                          Sharp 32BC2K0 << Could be an "O" as in Orange or a Zero
                                          Fault - Coloured "Bars" very thin all across the screen.
                                          I would like tho get the values for the 2 Resistors and I believe a Missing Capacitor.
                                          I would Like a Service Manual, that has the component values, and locations, as the PCB isnt that clear as for designations
                                          Is there such thing as a Boardview for this TV?
                                          I will Post the Photos in a second
                                          Stay Safe !...
                                          09-05-2024, 06:35 AM
