Sharp LC-42SB48UT-a no standby voltage
  • x_orange90_x
    Samsung UN55KU6300F no standby voltage
    by x_orange90_x
    I have no standby indicator light and no light on the optical port. I checked the standby voltage on the two mosfets in the top left and they both read 30mV. I checked the fuse and it has continuity. I also checked the voltage on the two large 450v caps they both read 153v. All of these voltages are the same with and without the main board connected as well as with backlights connected/disconnected.
    Nothing looks obvious like a burned ceramic disc cap or bulged electrolytic. No burned resistors, diodes, or anything like that....
    05-21-2025, 09:59 PM
  • Bad_IC
    Philips TV 37pfl5604h/12 no standby voltage
    by Bad_IC
    I have a problem with this TV, the standby voltage is not present. I have checked the components around the IC fsq510's area and they seem to work, also replaced this IC but the problem persists.
    These are the voltages in some pins of IC fsq510:
    Vcc=18v
    D=320v
    Vstr=154v
    Unfortunately, I couldn't find the schematic
    What else could I check?
    Is it possible to provide standby voltage from an external source to allow the TV to turn on?
    Thank you​...
    11-08-2024, 01:07 PM
  • brock-s
    Asus GL503GE 3.3 standby voltage low
    by brock-s
    An Asus GL503GE laptop arrived that had had a screw dropped on the motherboard while the battery was connected. This resulted in a physical damage to the 3.3v / 5v voltage controller RT6575DGQW (pu28 on schematic, page 40). Additionally, the trace to pin 12 (VIN 19v supply) was burnt.
    Replaced the RT6575DGQW with a new one, repaired the damaged trace. Only getting 0.7V instead of the expected 3.3v standby voltage (3V_S5 on schematic).
    Replaced the AON7408 PQ60 mosfet from a donor board as resistance was low on the gate (I did not write this value down, as I optimistically...
    07-13-2023, 03:43 PM
  • tvguy12012012120
    by tvguy12012012120
    02-07-2025, 05:13 PM
  • Bloutix
    Ps5 edm-033 bios and southbridge standby voltage
    by Bloutix
    i need your help for understanding if there is an issue around my bios on edm-033 and around southbridge pin P16 and P17.
    I have removed my Southbridge and when I check standby voltage on the bios, I’ve got this value:
    • pin 1: 0,16v
    • Pin 8: 3,3v
    • Pin 7: 3,3v
    I think there is an issue between 3,3v line and cs pin, but I don’t know where.
    then this are the values on SB P17 and P16: 0,93v, But I have 3,3v on L17.
    Thanks for your help....
    10-14-2025, 02:03 PM
