Re: Vizio e400i-b2 turns on backlights flash
One thing I do not know about the ACDET signal on this board if it it is LOW (<1vdc) ACV feeding the TV is GOOD (within the ac opersting range for the TV) and goes HIGH if the AC LEVEL is out of range, or if it is HIGH (>2.5vdc) when the AC feeding the TV is good and it goes LOW when AC is bad.
But I would expect the PS-ON to go low to shutdown the power supply if the ACDET detects problem.
So if you indicate that the PS-ON is present (>2.5VDC) but you do not have the switched 12VDC or the switched 24VDC, then you have power supply problem.
