Broken RCA L40FHD41YX9
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    Re: Broken RCA L40FHD41YX9
    This is ridiculous! I can't find the board for order on any site! It's always sold out or some equivalent that I'm not sure I trust. There's some on e-bay for around 80$! That's insane!!! Not really sure what to do. Has anyone ever tried one of those alternative ones? The ones that were made for another TV but modded to work with a different type TV?
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
    • Spork Schivago
      • Mar 2012
      • 4734
      Here's a link to some of the alternative styles. What do you guys think? Worth a shot or no? Style A there doesn't seem to be as long. Style B seems to be more of a direct fit...not sure the holes match up though, but 27$ is a lot better. I can get a used original on that site it shows for 40$ or something like that....that's a lot for a used version...
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Read my thread on how to repair this POS inverter:
        https://www.badcaps.net/forum/showth...=Ssi_400_14a01
        • Spork Schivago
          • Mar 2012
          • 4734
          I read your post ReeceyBurger123 on this inverter. Is it a good idea for me to attempt to repair it? From what I understand, this is a common problem with this actual inverter because of a poor design. Did I misunderstand your thread? If not, wouldn't replacing the faulty components just guarantee that after around the same amount of time that this TV has been on for (however many hours the owner had used it since they bought it), it'd just fail again, in a similar way?
          Because Tom66 tells us about the dirty little secret in that thread, wouldn't it be best for me to use one of the alternative styles I linked to? 27$ USD plus shipping (I'm guessing) for an alternative style...
          • Spork Schivago
            • Mar 2012
            • 4734
            Is this repair kit worth it? 14$ plus shipping I'd guess?
            http://www.shopjimmy.com/samsung-lj9...repair-kit.htm
            It comes with all those little SMD 8-pin ICs, I think they're MOSFETs. That big 28-pin IC and two replacement fuses.
            It'd look like it might not be crazy hard to fix, just a bit time consuming. I think those 8-pin ICs are large enough where I wouldn't need a stencil or anything for the solder paste. I could just lightly brush it on or maybe even just use my micros soldering iron that was designed for SMD rework....the 28 pin one would be a pain to hand solder but again, I think that'd be doable. Might be better just purchasing a stencil for that.
            What do you guys thinik? 14$ repair kit or 27$ replacement inverter (with shipping, 44$)?
            I don't know what ShopJimmy charges for shipping. The shipping from the other place is a bit expensive. The good thing about the other place though, the inverter wasn't made for this TV. It was just modded to work (or it just works), which mean, it shouldn't have the same issues I'd think...
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              #26
              Yeah deffo worth it, should make it more reliable also be sure to resolder all the smd parts as they have a habit of becoming lose and causing issues.
              • Spork Schivago
                • Mar 2012
                • 4734
                #27
                The customer made the decision to not go for the rebuild kit. I've ordered the replacement style B alternative. It came to around 44$. I left it up to them and gave them what I thought were valid pros and cons for both products. I'll let you guys know if replacing the inverter fixes everything or if there's more problems once it comes in the mail.
                Spork
                • Spork Schivago
                  • Mar 2012
                  • 4734
                  #28
                  Okay, today came the new inverter and it's got a little issues. It's physically smaller and doesn't bolt up at all. In fact, the board is actually smaller in length so where the screws normally go, I can actually see them next to the board, they're not under there. It's fairly secure inside the backlight connector though. They didn't make the add-on PCB quite right. So the tab connectors don't line up right with the backlight connector. I had to bend the board just a smidgen to get it to fit. Here's an issue though, the four pin connector that goes from the T-CON to the inverter on the other board, it doesn't have any connections on this one!!!
                  The 4-pin connector on the other inverter says: SYNC, NC, NC, GND for the pin-out. Finding a GND wouldn't be hard. But what the heck is sync used for? I didn't hook it up and tried the TV. It seems to work now. I didn't hook a video source to it, but I got the backlight on with the HDMI source listed. So, should I try to cut the 4-pin wire and solder one of the wires to GND and find where SYNC is supposed to go and solder the other wire to something on this new inverter or just leave it like it is and maybe tape the new inverter onto the TV or something?
                  Thanks!
                  • Spork Schivago
                    • Mar 2012
                    • 4734
                    #29
                    I was searching around and figured out what that 4-pin cable is from reading a post by Tom66. I'm quoting what he says from another thread here:
                    Code:
                    That cable is probably the sync cable for keeping the inverter synchronised with the t-con, it blanks the backlight when the t-con is updating the screen which creates the illusion of a faster screen update. It should be plugged in though it may work without it...
                    So the question is what to do with it because the new inverter is from a physically different television and doesn't include the hookup for this 4-pin cable. Is there some place on the new inverter where I could solder the new wire too? Here's some numbers I can read on the new inverter. Maybe one is the model number? I dunno:
                    Code:
                    IM3869
                    RDENC261 (white box) 0 (inside the white box) (back to green) TPZ (another white box) Z (inside the white box)
                    I googled the numbers and I think it's a Philips backlight inverter...it might also be called a:
                    ELEMENT ELCHW402 BACKLIGHT INVERTER BOARD IM3869
                    • Spork Schivago
                      • Mar 2012
                      • 4734
                      #30
                      I meant to say I did try the new inverter and it seems to work. Just curious if I should try finding a place t solder the SYNC wire to something on the new inverter. Tom66, you seem to know a bit about this SYNC stuff. Would you have any ideas? Thanks!
                      • chth96
                        Is it possible bridging tiny broken trace
                        by chth96
                        When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
                        cutting tiny trace.
                        This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
                        Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
                        But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
                        12-03-2022, 11:32 PM
                      • corrize
                        Where to find a very small fpc connector 0.3mm between 2 pins ?
                        by corrize
                        Hello, I search this connector (oxydated).
                        It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                        I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                        I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                        Do you know how to find this connector please ? What is the exact name for find it ?
                        08-06-2024, 05:25 PM
                      • Powderfanupnorf
                        Dell AL440LX power on switch circuit help required
                        by Powderfanupnorf
                        Hi Everyone. First official post so fingers crossed I conform and also manage to get photos to work.
                        So I am requesting some help from anyone who happens to have one of these motherboards to hand and perhaps a multimeter.
                        My board has a single row of header pins for all the front panel stuff (have seen others where they are grouped together differently so thats no help) and the two pins for the power on switch had been previously repaired and I am trying to make a better repair. There looks to be pad and trace damage and im happy to relocate the header pin/pins to...
                        06-24-2024, 01:24 PM
                      • SS454
                        vizio e650i-a2 backlight flashes then turns off
                        by SS454
                        vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                        panel: au optronics T650HVN05.4
                        72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                        link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                        Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                        https://www.shopjimmy.com/vizio-56-0...-power-supply/
                        Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                        08-20-2020, 03:57 PM
                      • FeerBaron
                        Got in way over my head with Supermicro server board and upgrade.
                        by FeerBaron
                        Last year I bought a server. It's worked fairly well but had some issues. Some pcie slots didn't work and Xeon v4 is a bit slow and missing AVX 512. Came to realize that the next version up, with skylake uses mostly the same chassis.
                        A board popped up on ebay one day being sold for parts. A working board like this is over a grand at best. This particular one was about $125 and I decided to gamble.
                        At first it seemed simple enough. According to the description it looked like some mechanical damage.
                        Found the missing 560uf cap and thought I was...
                        Starts
                        01-26-2024
                        Ends
                        01-26-2024
                        01-26-2024, 06:36 AM
