Panasonic TX-P42G20B swap in TX-P42S20B main board
    I can confirm that mechanically and electrically, minus one HDMI and VGA port, the S20B main board will drive a G20B panel, even though they have different SC and SS boards. The TV works fine now thanks to a board from Alastair.
    However, I'm unable to get Freesat or Freeview HD working. (Standard def Freeview is fine.) The S20B didn't ship with Freesat or Freeview HD, but the tuner boards are mostly compatible - I'm hoping that I'll be able hack the option list in the service menu such that I can get these to work.
    If anyone has a TX-P42G20B, please could you confirm the option settings. This is accessible by pressing VOL- on the TV and "0" three times on the remote (while holding VOL-). The first page that appears gives the option list - a photo of this from a G20B would be helpful! (To exit, power the TV off then on again.)
  • dj01fad
    • Sep 2014
    • 92
    • romania
    Re: Panasonic TX-P42G20B swap in TX-P42S20B main board
    hello Tom.
    I know someone that has a 42V20B; if this can help, I can try to ask him to send some photos from service mode.
    I have a 42GT20E or a V20E it this also can help you.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      I have a G20B but the SC needs to be replaced.
        Originally posted by dj01fad
        hello Tom.
        This might be useful if you could get this data, thanks!
          Swap your G20B main for my S20B main :-P
          • Diah
            • Feb 2013
            • 6376
            hello tom, this is the setting for P42G20E i think are same to B hope it help you can try after you record yours old value as backup.
            Option:
            Panel-Type : 42FHD
            Boot : ROM
            STBY-SET : 00
            EMERGENCY : ON
            Y/C Delay : 0
            OPT 1 : 00011100
            OPT 2 : 11101111
            OPT 3 : 00000001
            MIRROR : 00
            • Alastair E
              Chief Womble
              • Mar 2013
              • 1963
              • U.K.
              Be interesting to build up a basic What MB will run in what Panasonic set type thread....
              Would love to find summit to run a 37C2B and (if I recall correct) a 42G10B
              TELEFIX
              • Malachi
                • Dec 2015
                • 1077
                • Usa
                I have the a board from a 55vt30 in a 55gt30 but I'm guessing that's no big deal.
                • Diah
                  • Feb 2013
                  • 6376
                  if Mb work as electrical, then setting would work too in some how depend on ability. its all as HEX dec. so need to read then and convert to what you are wishing if the option was hidden. also at Panasonic there are destination area which limited function from land to land, there are 3 Option Conditional +EU and to France only and to Russia only choice what you want and post ühoto of yours OPT service menu an i will convert then to you.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Lol knock some £ off the kuro and its yours
                    • dj01fad
                      • Sep 2014
                      • 92
                      • romania
                      for the moment he is in holidays, so I'll try to get him enter the service mode when he comes back.
                      if you want my data I'll get into the service mode tomorrow and let you know.
                        Update, managed to get Freeview HD working with a retune but still not Freesat. I've decided not to risk messing up the configuration and will just sell the set as it is, with non-working Freesat.
                        This is probably my last repaired for profit TV I will do. I reckon this is the 100th I have documented on Badcaps out of around 200 or so.
                        Also bumped VSUS from LOW to HIGH in the service menu due to set having slight cyan maldischarge on white parts of the picture. Rare fault, not seen that outside of a Kuro!
                        Thanks all
                        • Andre Gilbert
                          by Andre Gilbert
                          11-20-2024, 08:52 PM
                        • AquaMan Ua
                          Problem with PANASONIC CF53 laptop after changing BIOS settings
                          by AquaMan Ua
                          Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                          05-17-2025, 09:40 AM
                        • stecos
                          Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                          by stecos
                          Hi everyone!
                          I happened several times, in the search for help from the web, to consult this very interesting forum.
                          So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                          Having said that I come to the gist of my post on the forum as the title suggests.
                          For my passion for technology I'm now collecting several...
                          11-28-2022, 11:39 AM
                        • aa10aa10
                          Panasonic Toughbook CF-33 mk1 BIOS repair
                          by aa10aa10
                          Good day,
                          I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
                          I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
                          01-21-2025, 06:13 AM
                        • Mnawar27
                          Panasonic CF-H2AU24EF3 bios locked
                          by Mnawar27
                          Hello ,my Panasonic CF-H2AU24EF3 I get bios password locked after factory reset, can't enter bios
                          I need help to remove it,
                          thankyou all.
                          SN; 2FKCA26876...
                          11-16-2024, 08:00 AM
