Samsung LN46C610N1F LCD TV no backlight
  • tech2014
    • Aug 2014
    • 807
    I can see video if I shine a flashlight on the screen, but I get no backlight. It doesnt even come on for a second. The fast track manual said to remove connector off main board and the BL should turn on as soon as power is applied. I still get nothing. Here are my voltages off connector CNi802 from the backlight inverter board to the power supply, I get the following voltages:
    CN802-
    Pin 1- VCC 12v=12v
    Pin 2-FB=0V
    Pin 3-FB=0V
    Pin 4 and 5 are GND
    Pin 6 and 7 LD=8.84V
    For PW dimming out on CN802 of p/s, I get 2V and H_out=1.66V
    I tested the PFC voltages and I get 388V on filter cap so PFC is good. I am suspecting the 2 large inverter transformers on the PS or the inverter board is bad.
    Re: Samsung LN46C610N1F LCD TV no backlight
    What is the board P/N BN44-XXXXXX? Samsung BN44-00341B? I suspect bad coupling cap, white rectangular cap CI818 0.47uF 450V POLYPROPYLENE in the middle of the board next to the heatsink for the MOSFETs that drive the inverter transformer. Look real close to see if is has bulge on the body.
    BTW, the fuse on the middle of the board is OK?
    • tech2014
      • Aug 2014
      • 807
      Bn44-00341b and fuse is good. I removed the capacitor and tried measuring the capacitance and get no reading, just OL.
      • tech2014
        • Aug 2014
        • 807
        Does anyone know where I can get this capacitor?
          Showing no capacitance at all?
          It will be PANASONIC POLYPROPYLENE type from DIGIKEY with 630V rating instead of the 450V rating.
          • tech2014
            • Aug 2014
            • 807
            I can't find this part on digikey. Anyone know? thanks
            • vinceroger69
              • Mar 2012
              • 6714
              http://ca.mouser.com/Passive-Compone...PYLENE&FS=True
              • R_J
                • 9557
                http://www.digikey.ca/product-search...=PCF1574-ND%20
                • tedjar
                  • 51
                  Just want to report that this this thread saved another TV...
                  I had a Samsung LN46C630K1FXZA with the same issue. Power on, works normally if you shine a light at the screen, no backlight at all. All electrolytics looked ok. Power supply is the same BN44-00341B. The poly cap was bad, completely open. It even had the little bulge on the side of it. Replaced it with DigiKey P/N: PCF1574-ND - Panasonic / ECW-FA2J474J CAP FILM 0.47UF 5% 630VDC RADIAL and the TV is back to normal.
                    Thanks for the report, I wish the OP has done the same.
                      09-07-2024, 05:50 AM
                    • sansanpartida
                      Samsung QE82Q70RAT no backlight
                      by sansanpartida
                      Hi everyone!
                      Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
                      My issue: No backlight.
                      Model: QE82Q70RAT
                      Type No: QE82Q70RAT
                      The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
                      So hopefully, I can fix this cheaper.
                      05-22-2024, 06:56 AM
                    • howardc64
                      Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                      by howardc64
                      TV was fixed just after removing Samsung's rear snap cover.
                      This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                      Maybe PSU->backlight connector didn't have a good contact?...
                      07-23-2025, 12:34 AM
                    • howardc64
                      Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                      by howardc64
                      • Prior owner tried a replacement main board. No difference.
                      • Samsung 2x red blinking standby LED = panel fault
                      • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                      • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                      • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                      07-19-2025, 10:54 PM
                    • Ierwin
                      by Ierwin
                      05-13-2025, 03:31 PM
