Samsung UE32F5500AW no picture
  • rtstorm
    • Feb 2012
    • 971
    • Croatia
    Hello, i got this smart TV that turn on and dont have picture.
    Model: Samsung UE32F5500AW
    When turn on backlight is turn on, and all other function work but no picture.
    I check voltages on PSU it have 13V and 5V
    Tcon board have 13V on some parts, some are 0.2V
    Any ideas?
    ...the quieter you become the more you are able to hear...
    Re: Samsung UE32F5500AW no picture
    What do you get if you only has one ribbon cable between the T-CON and the LCD panel connected one at a time?
    • rtstorm
      • Feb 2012
      • 971
      • Croatia
      I get the same thing, only backlight turn on.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        I have the same Tv same issue and Ic on the Tcon is failed. Will link thread.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Check this out, test Ic200 against the schematic. I have mine on order should sort it:
          https://www.badcaps.net/forum/showth...ighlight=Runtk
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            On the Tcon board there is a fuse F100. Have you checked if it has blown open circuit. There are also other points on the TCON board you could check.
            VGH, VGL, VCC1.2V, VIN12V
            • rtstorm
              • Feb 2012
              • 971
              • Croatia
              Hey i check some pin on ISL9860
              pin 39 (SWOUT) - 0V
              pin 12 (GHC) - 0V
              pin 13 (GHD) - 0.2V
              pin 20 (PHASE2) - 0V
              pin 30 (PVIN) - 13V
              pin 8 (DRVP) - 0V
              So i guess that it has no output.
              Fuse F100 - ok
              VGH - 0V
              VGL - 0V
              VCC1.2 - 0V
              VIN12V - 12.9V
                it does look like IC200 is the problem then.
                • rtstorm
                  • Feb 2012
                  • 971
                  • Croatia
                  Ok i will try to replace it and post result
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Same here deffo common on these. Heat from under the board to remove and replace the chip. Also dont forget to heatsink the replacement to help improve reliability.
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      Glad you found the fault. Are you going to attempt to replace the IC.
                      • rtstorm
                        • Feb 2012
                        • 971
                        • Croatia
                        Yes i am, i will post result when i replace it.
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Im also doing the same on my thread. Keep us posted if you get your Ic before me lol
                            BTW, when you are done, make sure to turn down the backlights level to as low as possible to extend the life of the LEDs which is more likely to be the next failure.
                            • rtstorm
                              • Feb 2012
                              • 971
                              • Croatia
                              Hello i replace the IC200 but still no picture. Now the IC is getting hot, i check for shortages but there is no short in solder pins
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                Hmm thats not good, deffo soldered properly ? I just hope now I can sort mine as had customers for a while now lol
                                • rtstorm
                                  • Feb 2012
                                  • 971
                                  • Croatia
                                  I order 5 of those IC, i can solder another one but i doubt.
                                  Here is the photo of my solder (i use hotplate)
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    Hmm looks good, unsure tbh maybe your main processor is fried as well ? Will see if I can find anything on the internet about this board.
                                    • Diah
                                      • Feb 2013
                                      • 6611
                                      on the photo you have short contact at pin 7 with No 6 its solder running down.. take a look
                                      • rtstorm
                                        • Feb 2012
                                        • 971
                                        • Croatia
                                        well i put new IC again, and not i do not have overheating (still no picture)
                                        i check voltages and here is what i have now:
                                        pin 39 (SWOUT) - 0V
                                        pin 12 (GHC) - 0V
                                        pin 13 (GHD) - 2V
                                        pin 30 (PVIN) - 12.9V
                                        pin 8 (DRVP) - 0V
                                          09-07-2024, 05:50 AM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • JJAAMM
                                          by JJAAMM
                                          Problem
                                          07-06-2023, 06:01 AM
                                        • shelby5041
                                          Samsung LCD TV no picture backlight on no 12v at tcon
                                          by shelby5041
                                          hi
                                          i have a samsung lcd tv
                                          it powers on with sound and backlight but no picture
                                          all voltages from PS are good 12v 3.3v and 5v
                                          whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
                                          i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
                                          no 12v at the tcon fuse
                                          i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
                                          the odds of having 2...
                                          10-08-2021, 08:21 AM
                                        • Dodgethis
                                          Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                          by Dodgethis
                                          Hello all,
                                          This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                          09-11-2024, 07:39 AM
