Samsung UE32F5500AW no picture
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    #41
    Re: Samsung UE32F5500AW no picture
    Im quite sure you main processor is at fault, it is responsible for turning that booster on from what I can tell.
    • rtstorm
      • Feb 2012
      • 971
      • Croatia
      #42
      I found that PHASE2 is shorted to GND maybe that produce all the problems. Maybe the shortage is in main processor. Is it ok to remove the processor and then check for shortage?
      Main processor is BGA type KL5T3067
      ...the quieter you become the more you are able to hear...
      • rtstorm
        • Feb 2012
        • 971
        • Croatia
        #43
        Well i removed the processor and shortage is gone, so i guess the problem was main processor.
        What do you think?
          Well, it looks like you narrow it down to the cause of the problem.
            BTW, the FET201 that you removed, does it tested as shorts between the S and D pin of both MOSFETs?
            • rtstorm
              • Feb 2012
              • 971
              • Croatia
              #46
              I tested the FET201 for shortage and it is ok.
              I also try to remove the main processor and put it back, as soon as i put back the CPU the shortage retrned
                Well, it is may be time for a new board.
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  #48
                  Yep as I suspected. Fucking crap these boards are, if only they heatsunk them devices these would have lasted. Unless you have a bga station you will need a new board you can find the processor though on google, I dont so I hope its only IC200 faulty on mine.
                  • Diah
                    • Feb 2013
                    • 6614
                    Originally posted by ReeceyBurger123
                    Yep as I suspected. Fucking crap these boards are, I hope its only IC200 faulty on mine.
                    yours !C200 was getting hot right.. will pray for you to be IC200 only... but believe my pray don't reaches the heaven LOL
                      You already tested the outputs for shorts already so you may be OK, if the upper MOSFET of the FET201 shorted out then it can dump 13V to the PHASE2 (2V Buck regulator) output and damage the ICs.
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        #51
                        Lol Diah cheers
                        • rtstorm
                          • Feb 2012
                          • 971
                          • Croatia
                          #52
                          I have bga rework machine, but on aliexpres whole board is 50USD so it is not worth to repair this. I will ask customer if he want to replace board
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            #53
                            Try replacing the chip ? How do you know the board off Ali is going to last if its used ?
                            • rtstorm
                              • Feb 2012
                              • 971
                              • Croatia
                              #54
                              It say it is new hahah, i will put heatsink on power IC and CPU
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                #55
                                Lol also yes out a heatsink on all 3 chips on the board, I will if I fix mine or replace it. All these Leds are shit, also after you fix it dont forget to turn down the backlight
                                • rtstorm
                                  • Feb 2012
                                  • 971
                                  • Croatia
                                  #56
                                  My client do not want to repair it any longer so its a cancel.
                                    09-07-2024, 05:50 AM
                                  • TR103
                                    by TR103
                                    - it keeps rebooting
                                    01-22-2025, 04:12 PM
                                  • JJAAMM
                                    by JJAAMM
                                    Problem
                                    07-06-2023, 06:01 AM
                                  • shelby5041
                                    Samsung LCD TV no picture backlight on no 12v at tcon
                                    by shelby5041
                                    hi
                                    i have a samsung lcd tv
                                    it powers on with sound and backlight but no picture
                                    all voltages from PS are good 12v 3.3v and 5v
                                    whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
                                    i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
                                    no 12v at the tcon fuse
                                    i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
                                    the odds of having 2...
                                    10-08-2021, 08:21 AM
                                  • Dodgethis
                                    Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                    by Dodgethis
                                    Hello all,
                                    This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                    09-11-2024, 07:39 AM
