lines on screen Manta LED4201
+ More Options
Posts
  • andyfitz48
    • Feb 2016
    • 17
    • united kingdom
    Hi
    Picked up the above tv today and initially the picture came on but appeared washed out, lacking greens.
    Suspected the Tcon so reseated all connections and much jiggling later all the screen displays is a screen full of multicolour vertical lines. Sound is fine.
    Im having probs uploading fotos from my tablet but does this sound like a tcon fault before I try to track down a replacement or a bad panel? Cheers
    Andy
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: lines on screen Manta LED4201
    Got images please mate of the screen and boards ?
    • andyfitz48
      • Feb 2016
      • 17
      • united kingdom
      Hi
      Still unable to upload fotos from my tablet but think it is a faulty tcon.
      Having no luck tracking down a replacement. Not even ebay has them, its an e8844194v.
      Does anyone know where I could pick one up or even somewhere which can fix them.
      Much appreciated
      Andy
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Sounds more like Mb to me tbh Andy. Would need images though to get a better idea sorry.
        • andyfitz48
          • Feb 2016
          • 17
          • united kingdom
          Thanks for the help.
          I'll try to get the fotos on tomorrow
          Andy
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            No worries keep us updated.
            • andyfitz48
              • Feb 2016
              • 17
              • united kingdom
              Andy
              • andyfitz48
                • Feb 2016
                • 17
                • united kingdom
                Fotos attached but may need more detailed ones as only took these for spares comparison
                thanks
                Andy
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  I would likely say panel failure on that tbh bud.
                  • andyfitz48
                    • Feb 2016
                    • 17
                    • united kingdom
                    Thanks for the suggestion though I still think I'll try a new tcon - if I can find one.
                    Scoured ebay and they seem to be rarer than hens teeth so can anyone suggest where else I can try? Also tried flattvparts, spares2repair etc.
                    Cheers
                    Andy
                      Are you getting steady 12VDC at the T-CON fuse? and standby Voltage is steady and not low? I have seen this symptom before due to border line standby Voltage or the switched 5V.
                      • andyfitz48
                        • Feb 2016
                        • 17
                        • united kingdom
                        Yes, I was when I 1st opened it up and the picture was displayed though washed out.
                        Didnt test it after id jiggled with the ribbon cable and the screen went to just vertical lines.
                        Andy
                        • andyfitz48
                          • Feb 2016
                          • 17
                          • united kingdom
                          Still trying to find a tcon for the Manta TV. The con is a c6870 0328a v0.6.
                          There is 1 of these on ebay but does the replacement need to be not only the same part number but from the same TV or will any c6870 0328 v0.6 work in my set? Thanks
                          Andy
                          • Stanley1843
                            by Stanley1843
                            06-29-2024, 11:54 AM
                          • jeyoung12
                            Samsung QN50Q60t lines on screen
                            by jeyoung12
                            Hi all
                            I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
                            My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
                            This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
                            It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
                            So....i don't know what end of the C ribbon to work with...
                            02-26-2024, 10:38 AM
                          • Ryan.man
                            by Ryan.man
                            02-04-2025, 12:23 PM
                          • kdaniel
                            Hitachi 58HK6100U - Horizontal Lines (Bottom third of the screen)
                            by kdaniel
                            As stated by the person I collected the TV from, it just stopped working overnight. However, I still gave it a go to try and repair it.
                            There is a thread on the same TV but with slightly different issues where they had to tape connection points on the ribbon cable, so I want to see if this is repairable by any chance.
                            After bringing it home and plugging it in, the TV turned on with its backlight working but had no picture. After removing the back cover, the first thing I tried is to unplug one of the ribbon cables and the situation is as follows.
                            Left...
                            11-16-2022, 09:23 AM
                          • Chrissygizmo
                            Sony KD-55XG9505 lines on screen problem
                            by Chrissygizmo
                            Hello again everyone,
                            This is my latest mission, to try getting this Sony tv back to normal working order…
                            I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                            02-19-2025, 11:31 AM
