Panasonic TX-P50UT30B 6 blink error
    I'm struggling to fix Panasonic plasma TX-P50UT30B.
    TV doesn;' turn on and LED blinks 6 times.
    Faulty is SC board like usually it this case it's TNPA5351 AF
    I have changed already Q622, Q623, Q600 and Q661 which all were shorted.
    After that TV still doesn't turn on showing 6 blinks, no shorts fortunately after powering up.
    Later I swapped from my other death boards PC685, PC581 and IC921 but it didn't change situation unfortunately. Both buffers I swapped from my TX-P50ST30B.
    I have found no other shorts.
    I will appreciate any help to solve this problem.
    Re: Panasonic TX-P50UT30B 6 blink error
    If those parts came from 'death-boards' as you say, can you be sure they are good?
    TELEFIX
      only those ( PC685, PC581 and IC921) came from faulty SN board like TNPA5330 or TNPA5457 with faulty buffer chips which I have used as source of parts.
        http://www.toms-service-manuals.com/...h=Submit+Query
        TELEFIX
          maybe check all the drive ccts.
            Thank you very much for those slides, I haven't seen them before.
              Neither have I, wish i had them when i struggled with the TNPA5335 which I'm still not 100% sure which bit I did fixed it.
              Really interested to see how you go in diode checks on those 8 pin driver buffers.
              I always think when bits stop blowing up you're close.
              It seems to me if you get 621, 622, 623, 661 etc are bown it's a dificult repair.
              Also I don't see any 6 blink repair kits for the 5351 or 5335 so it would be good to see what it is we're missing.
                Just fixed this same model TV.
                I thought I would post up what I found for other people.
                TV had no blink code at all. Just a solid green light and no panel discharge.
                The 30F131 transistrors on the SC board were shorted only.
                Replaced them, now I get a 6 B blink error code.
                Replaced both DG302 transistors and a hole heap of the small 5 and 8 pin ICs and transistors. Everything that came up in a search, still no go.
                Turned out to be the green LED D583.
                  :-).... that's rather interesting. Did the LED actually light and then go out or didn't even light?
                    I never noticed it lighting during the multiple tests.
                    I only found it because I was testing the whole SOS6 circuit in diode test mode.
                    Looking back Tom did mention in one of the posts to see if it was lighting briefly, but I was focused on all the common faults that I didn't even think to check.
