Dead BN44-00458B
    Dead BN44-00458B
    Normally if few caps are faulty, I normally see the standby light, in most case.
    This board is dead. No standby light. Fuses, caps and diodes are ok. AV board bad?
    Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails Developer
    Re: Dead BN44-00458B
    Why has the photo got things in Red ? You diagnosed it ? Checked voltages ?
      Is that your board? Any good clear straight shot picture of the bottom side of the board?
      DCV between the two legs of the main filter cap?
        Sorry, guys. I've left work. Red circles are what I've replaced with new and still dead. I'll do those tests tomorrow.
          Why did you replace them though ? Did the original diodes test bad ?
            I thought they were short. But it turns out they are short when in circuit.
              Ahh I see
                BTW, so you do not have A5V at pin 14 of the connector CNM803 when you do not have other boards connected to it?
                  No voltage on pins of caps where the red circle is on picture above.
                  Image of reverse:
                    No voltage on the 450v cap's pins.
                      Do you have 240AC between the two inner pins of the bridge rectifier?
                      If you do, then what DCV you have on the two outer pins of the bridge rectifier?
                      I would also resolder the pins of the transformers, the bridge rectifier, the legs of the devices mounted on the heatsinks.
                        Red: 338DCV
                        Yellow: 247ACV
                        Seems ok on the bridge rectifier. I have not seen any colder solder points. But can resolder. Anything else to check as 0v is going to the AV board?
                          OK, now we have established that we do have main DC to run the SMPS, now we need to get the standby power supply up and running first.
                          ICS801S is the standby SMPS IC, we need to get the P/N to get the pin out to find out if we have VCC and the 338VDC to feed the standby transformer TS801S or not.
                            Thanks. I'll investigate from here then let you know.
                              might be worth checking all these parts in the repair kit for this board
                              http://www.ohmsupplies.co.uk/REPAIR-...01-FAULTY-DEAD
                                Ok. Bought a used "working" board off eBay. Standby light comes on. Pressed to turn on, red light blinks then goes back solid red. Bad board or main board?
                                  What voltages do you have or not have on connectors CNM803 and CNL802
