Dead BN44-00458B
  • speedypro
    • Feb 2013
    • 561
    • United Kingdom
    Dead BN44-00458B
    Normally if few caps are faulty, I normally see the standby light, in most case.
    This board is dead. No standby light. Fuses, caps and diodes are ok. AV board bad?
    Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails Developer
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Dead BN44-00458B
    Why has the photo got things in Red ? You diagnosed it ? Checked voltages ?
      Is that your board? Any good clear straight shot picture of the bottom side of the board?
      DCV between the two legs of the main filter cap?
      • speedypro
        • Feb 2013
        • 561
        • United Kingdom
        Sorry, guys. I've left work. Red circles are what I've replaced with new and still dead. I'll do those tests tomorrow.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Why did you replace them though ? Did the original diodes test bad ?
          • speedypro
            • Feb 2013
            • 561
            • United Kingdom
            I thought they were short. But it turns out they are short when in circuit.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Ahh I see
                BTW, so you do not have A5V at pin 14 of the connector CNM803 when you do not have other boards connected to it?
                • speedypro
                  • Feb 2013
                  • 561
                  • United Kingdom
                  No voltage on pins of caps where the red circle is on picture above.
                  Image of reverse:
                  • speedypro
                    • Feb 2013
                    • 561
                    • United Kingdom
                    No voltage on the 450v cap's pins.
                      Do you have 240AC between the two inner pins of the bridge rectifier?
                      If you do, then what DCV you have on the two outer pins of the bridge rectifier?
                      I would also resolder the pins of the transformers, the bridge rectifier, the legs of the devices mounted on the heatsinks.
                      • speedypro
                        • Feb 2013
                        • 561
                        • United Kingdom
                        Red: 338DCV
                        Yellow: 247ACV
                        Seems ok on the bridge rectifier. I have not seen any colder solder points. But can resolder. Anything else to check as 0v is going to the AV board?
                          OK, now we have established that we do have main DC to run the SMPS, now we need to get the standby power supply up and running first.
                          ICS801S is the standby SMPS IC, we need to get the P/N to get the pin out to find out if we have VCC and the 338VDC to feed the standby transformer TS801S or not.
                          • speedypro
                            • Feb 2013
                            • 561
                            • United Kingdom
                            Thanks. I'll investigate from here then let you know.
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              might be worth checking all these parts in the repair kit for this board
                              http://www.ohmsupplies.co.uk/REPAIR-...01-FAULTY-DEAD
                              • speedypro
                                • Feb 2013
                                • 561
                                • United Kingdom
                                Ok. Bought a used "working" board off eBay. Standby light comes on. Pressed to turn on, red light blinks then goes back solid red. Bad board or main board?
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  What voltages do you have or not have on connectors CNM803 and CNL802
                                  • k370
                                    Yoga3 Pro-1370 Board NM-A321 DEAD no power at all
                                    by k370
                                    I have a NM-A321 board that is dead, with no power at all.
                                    When I received the laptop, the +5VPMIC line was shorted. Removing the PU3 (ISL95905) solved the short, so I ordered and replaced the ISL.
                                    With the new ISL, the short is gone, but still no voltages at all. I measured the following rails:
                                    • +3VALW
                                    • +5VAUX
                                    • 1.2VSUS_PWRGD
                                    • 3VALW_PGD
                                    • 1.05VAUX_PWRGD
                                    Additionally, the ISL95906 (PU3) is not getting any voltage on the VIN rail.
                                    The only place on the board where I find any voltage is on the first MOSFETs, specifically:...
                                    09-23-2024, 11:57 AM
                                  • howardc64
                                    by howardc64
                                    07-24-2025, 05:17 PM
                                  • corrize
                                    Nikon D5 – dead, power board issue ?
                                    by corrize
                                    Hello, the DSLR has heavyly fallen. It is dead : no sign of life and display nothing.
                                    When it worked, it always displayed a card present state on LCD display, even when the battery is empty it display a empty battery symbol.
                                    I found a dead fuse, I replaced it and a mosfet burnt, I changed it and another fuse burned. Nothing burned after. And I can't find any short circuit anywhere, it's weird.
                                    Now, I try to understand how it works.
                                    There is two boards (the little one on pictures has no component) : the first is a « power board » : managing...
                                    04-03-2023, 09:13 AM
                                  • tvguy12012012120
                                    by tvguy12012012120
                                    02-07-2025, 05:13 PM
                                  • fharris1977
                                    Vizio D50u-D1 Dead Set No Standby
                                    by fharris1977
                                    Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                    12-28-2023, 10:25 AM
