Moving LCD Panels
  • SLK001
    • May 2014
    • 264
    Moving LCD Panels
    I have been moving around LCD panels by keeping them vertical. However, this gets to be a problem when reassembling them into TVs after replacing either LEDs or CCFL tubes. I would like to know what others are using to prevent damage to the LCDs in disassembly and reassembly.
    I was thinking of getting two of these suction cup lifters from my local HF. The end to end dimension is approximately 12". Does anyone have better solutions?
    https://www.badcaps.net/forum/attach...1&d=1462850256
  • rockit711
    • Nov 2015
    • 63
    Re: Moving LCD Panels
    Someone may have experience with those suction things and LCDs, but I would have thought it would be a risk they may apply enough suction that they break the thin LCD glass.
    Might be able to get something like that with "weak" suction that would work well though?
    • chrismurphy
      • May 2014
      • 251
      • australia
      I leave them in the plastic frame with some tape from the frame to the panel to stop the screen falling out
      • flocko
        • Nov 2012
        • 1121
        I use a sheet of thick brown rapping paper (I have a roll 48" wide) , and slide this under the panel from the end without the tabs, then with a second pair of hands lift away like you would with a person on a blanket.the paper supports the screen and refitting it is just the reverse. I have with help used this for screen sizes up to 70" with no problems. I hope this is of help to you Flocko
        • eccerr0r
          Sell or Shim Solar panels?
          by eccerr0r
          Well, due to my grid tie inverter not accepting high voltages, and the fact that the lions in my solar panels are 36V (72-cell) I think I need to stick with 72-cell.
          However I have a few smaller panels that are 36, 32, and two 30-cell. The 36 and 32 together run at 75% efficiency (and subtract more with additional inefficiencies) when running in parallel with the 72-cell panels. The kicker is that the two 30s... generate 0% power when connected in parallel(!)
          So now what to do with these small panels?
          I could sell them...
          Or I could shim them....
          03-29-2025, 01:07 AM
        • howardc64
          by howardc64
          Problem
          08-04-2024, 10:36 PM
        • ronaldopdias
          14" MacBook LCDs - has Apple re-introduced a new serialisation type?
          by ronaldopdias
          Since about a month or two ago, we've observed a new type of 'serialisation' on the LCDs and we're just curious whether anyone has seen this
          • New LCDs straight from the factory (not programmed)- if the Mac is restarted or switched on from a cold boot, you must close the lid, then open it again (so two cycles of opening and closing the screen) in order to get display.
          • Transplant the IC onto another screen:
            • If the model and revision match exactly then it will perform as normal
            • If the manufacturer matches exactly BUT its a different revision, the colours are mostly in
          06-28-2025, 09:56 AM
        • jason123
          Epic failure of the screen suction holders
          by jason123
          Just sharing a failure of the suction cups used for screen removal. I don't know if these require special maintenance, but they came with no literature.
          Today i was repairing a Vizio E70-E3 (70" 4k TV) with bad backlight. One of the suction cups failed and the panel hit the ground and shattered. I got these from SJ so they're supposed to be decent quality.
          Anything you guys do to maintain the rubber on these? I wipe them with damp rag before use, then wipe dry. Any hints / tips?
          10-06-2022, 02:39 PM
        • NolesFan
          Can LED panels be used from different TV's ( or the internals to the panel )?
          by NolesFan
          I have a TV, ( example ) Sony XBR-75X80G that the LED panel is cracked, does anyone know if we can take the LED panel from a ( example ) Sony XBR-75X80H and plug it in and it will work? Or if the panel measurements is not exact, can we take the internals of the cracked panel 80G TV and mount into the good panel 80H TV? Thank you
          06-23-2025, 09:19 AM
