Samsung UE46F6500 no standby light, does not turn on
  • Dirt
    • May 2016
    • 6
    • Hungary
    Hi Forum!
    I have a problem with the above mentioned TV. It has no standby light and does not turn on. There's no visual damage on the powersupply panel, the fuse is ok.
    When I unplug the mainboard the PS_ON/OFF pin produces 3.3V and the backlight turns on.
    Is it a power supply problem? I've also read it could be a corrupt firmware.
    Re: Samsung UE46F6500 no standby light, does not turn on
    Please upload good clear pictures of the whole backside of the TV so we can see all the boards, at this point it looks like you have main board problem.
    • Dirt
      • May 2016
      • 6
      • Hungary
      Sorry! Forgot about that.
      • CapLeaker
        Leaking Member
        • 8130
        Sounds like a main board problem indeed.
        • Dirt
          • May 2016
          • 6
          • Hungary
          Is there a way to troubleshoot the mainboard or reflash the eeprom? I've been to a technician, he said after 3 days, that the power supply needs to be replaced and he'll even do it for a mere 280$. That's when I checked it myself.
          • thoma
            • Sep 2012
            • 268
            What happens when you connect mainboard power supply
            and disconnect T-Con?
            regards thoma!
            • Dirt
              • May 2016
              • 6
              • Hungary
              regards thoma!
              Nothing changes.
              • Dirt
                • May 2016
                • 6
                • Hungary
                Is there a way to rule out the power supply 100% ?
                Has anyone tried repairing a mainboard? Replacing eeprom?
                Does the replacement mainboard's number has to match 100% ?
                  Post 1: When I unplug the mainboard the PS_ON/OFF pin produces 3.3V and the backlight turns on.
                  Power supply/LED driver board is OK.
                  • tsorbatzis
                    • Mar 2016
                    • Ελλάδα
                    the problem is on the mainboard.The technician gave you wrong diagnosis
                      • 12129
                      • U.S.
                      Very good conclusion but you're about 3 years late.
                      • ChristianBr01
                        LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                        by ChristianBr01
                        I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                        The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                        What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                        04-23-2025, 01:48 AM
                      • Kaar3l
                        Samsung QLED QE65Q7FNAT only standby light
                        by Kaar3l
                        TV: Samsung QLED QE65Q7FNAT
                        PSU: BN4400940A
                        MB: BN94-12832K
                        I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                        09-24-2024, 01:35 PM
                      • Nicktronic
                        Samsung UN70NU6070F Standby Light flashes twice
                        by Nicktronic
                        Hey Everyone,
                        So I've got this Samsung and the reported issue is that when powered on the backlight comes on, but no picture, no sound, it will flicker, the standby light will flash red twice and repeat the whole process...each loop lasts about 15 seconds.
                        I've googled the issue and understand it is likely a panel/driver board issue, but was hoping the "tape method" could be successful. Before I did that though, I disconnected the left LVDS cable and powered the TV on. This time I got sound, no picture and the two blink standby light stopped. Did the same...
                        03-27-2023, 07:01 PM
                      • PNI E.
                        Samsung ue55tu7170u not turn on and no standby led main bn9650990e
                        by PNI E.
                        Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
                        03-17-2025, 04:23 AM
                      • Jackching
                        Samsung UN46EH5000F wont turn on. Blinks red standby light continuously
                        by Jackching
                        I know for sure it has a bad cap and one cold solder joint. Just wondering before i order the Caps if anyone has any experience with this model? Just making sure there isnt a common component that goes bad besides the caps....
                        04-15-2024, 05:14 PM
