LG PDP60R40000 No Signs Of Life
  • Todd1
    • Apr 2016
    • 4
    Hi, I have an LG that has no signs of life on the outside, no power LED, video, or sound. All output voltages on the power board EAX64276701 tested normal and per spec. The mainboard EAX64280504 has a constant red light at part LD500.
    The Tcon EBR73749601 has a flashing green light at D101 with repeated cycles of one long, one short.
    I have not sure about which direction to take troubleshooting this issue and any help would be appreciated. Thank you
  • tw2005
    • Oct 2011
    • 6458
    Re: LG PDP60R40000 No Signs Of Life
    don't know a lot about the LGs but on the logic control board ther are 2 pads marked auto-gen.
    I believe you can jumper those together, disconnect the LVDS ribbon from the main board, disconnect the power lead from the main board to the psu. plug it in and turn on at the wall it should auto turn on and then display a sequence of test patterns.
    Also the model , probably 60PAxxxx,
    • Todd1
      • Apr 2016
      • 4
      Ok found it. Just not sure exactly what to jump, the orange circles or the resistors together?
      • tw2005
        • Oct 2011
        • 6458
        The orange circles which should be copper pads
        • Todd1
          • Apr 2016
          • 4
          Cheers, not too familiar with the terminologies haha. No change when I bridge the connection with a screwdriver.
          • tw2005
            • Oct 2011
            • 6458
            did you follow all the steps? Can you be sure a screwdriver made contact? If you have a soldering iron I'd solder a wire link but if you're sure you did everything right then that would suggest it's in protection due to a failed driver board or buffers.
            Only thing to suggest would be to use a multimeter and go looking for shorted out transistors or shorted buffer boards. The transistors to check woulfd be the heatsinked items with positions labelled Qxxx, Dxxx are diodes.
            I'd start with the ysus board
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Images of the back of the set ?
              • davidk35
                Lenovo ThinkBook 15 G2 ITL, some little signs of life
                by davidk35
                So i got above mentioned laptop. Which shows only some little signs of life.
                When i turn it on, 3 buttons lit up and stays like that forever (ESC, Caps Lock and Num Lock), they dont blink, they are just lit all the time. Fan does not spin, and there isnt any heat from CPU.
                What ive already done:
                -Flashed both bios chips 16 and 8 mb.
                -Tried adding another stick of ram
                -Check if backlight is faulty.
                So any ideas?
                Thank you
                09-03-2025, 06:34 AM
              • KYBOSH
                Trying to Save - Samsung 65" The Frame (QN65LS03B) with no signs of life (One Connect Box)
                by KYBOSH
                I picked this one up today.
                Previous owner says no signs of life.
                TV looks immaculate and its a 2022 model year so I thought maybe the one connect cable was damaged.
                Got it home and put it on the Kill-A-Watt power meter and it was completely dead.
                The TV model is QN65LS03BAFXZA - version: CB06
                The One Connect Box BN44-01066D / BN96-54788Q / BN39-02470A.
                I immediately remembered EazyBone's Samsung The Frame TV no power....One Connect thread and am preparing myself to tear the One Connect open and hunt for dead parts.
                Will keep you all...
                04-05-2025, 08:32 PM
              • someonenotyou
                Dell Vostro 3501 - no signs of life after BIOS read
                by someonenotyou
                Hi.
                I have a laptop Dell Vostro 3501 which did not POST. When connected to power supply and turn it on, the keyboard backlight would turn on but nothing else. Sometimes there was 1 BEEP code indicating problems with BIOS.
                Then I disassembled it to read the BIOS chips. It had 2 - 64mbit and 128mbit. I connected CH341A (with 3.3v mod) to both of the chips (still soldered on main board) and read them.
                After I reassembled laptop back and tried to turn it on. Now there is no sign of life. Not even keyboard backlight.
                Then I took the motherboard out...
                01-27-2025, 05:15 AM
              • tranquility
                HP EliteBook 850 G5 without signs of life
                by tranquility
                hello, i have a problem with HP EliteBook 850 G5
                shoring no signs of life. led near charging port and on/off button are off.
                board it taking just a few mA..i think it was 10mA
                i measured some things but i don“t find anything
                the ACOK ? pin 24 FRWPG (pin 24) am ISL9538h is low with 0V
                but i dont know why
                i cant really understand what the mosfets in the pictures are doing for crazy things.
                i measuered voltage on coils....but now on mosfets near the coils too and they all had more than 10v i think one was there with 8v or something....so...
                12-02-2024, 05:57 AM
              • KYBOSH
                Trying to Save - Samsung UN40MU6300 - No Signs of Life
                by KYBOSH
                Picked this one up today.
                No signs of life whatsoever. No red led light from the IR module.
                Disconnected the mainboard to see if PSU was working and it was (LED backlights lit up).
                Checked the power button for continuity when buttons were pressed and I got readings.
                Disconnected various components (speaker, wifi module) with no difference.
                Checked mainboard's fuses (found 3) and they were all good.
                I looked on shopjimmy to see what components I may have been missing and I saw that they were selling EEPROMs.
                Then it dawned...
                10-12-2024, 11:20 PM
