Post The Led Backlights Your Fixing Here.
https://www.facebook.com/Telford-Tel...7894576335359/Comment
Re: Post The Led Backlights Your Fixing Here.
well what a load of crap these LG led tvs are becoming LG 32LB550B no backlight
screen type "Heesung HC320DXN-VHHR2-51XX" / SHARP
they have massive lenses on them look like bi-focals lol i have had to pop each lens off out of the 18 leds only 2 work the 16 faulty ones are o/c s/c or read hi this is gonna be fun to do ??
Does anyone know what leds they use and where to get replacments please thanksComment
Does anyone know what leds they use and where to get replacments please thanksPlease Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
If they are the large LG lens Type they will not light with meter in diode mode? they run at 5.5-6.00 v you meter will put out under 3.00v in diode mode. if you have a 9v battery testing in pairs will show a glow from each pair. ebay item 252492958756 lens type C, I have some new strips also for 32" FlockoComment
If they are the large LG lens Type they will not light with meter in diode mode? they run at 5.5-6.00 v you meter will put out under 3.00v in diode mode. if you have a 9v battery testing in pairs will show a glow from each pair. ebay item 252492958756 lens type C, I have some new strips also for 32" Flockowell glowed lol
how much for 3 strips Flocko mates rates pmsl
GaryLast edited by comptek; 08-22-2016, 01:18 PM.Comment
His name is John but dont worry I got it wrong as well hahaPlease Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
https://ru.aliexpress.com/item/50pcs...08.4.29.cPZHb4Comment
what about something like this?
well flocko says
so if this was my set i would probs take a chance.Comment
by PipolupsHi there !
I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...10-08-2024, 11:58 AM -
by TrisHClHi,
First post...
I have this TV, which was working, then suddenly would not turn on. It would get the clicking relay then flash up the screen for less than a second, off for a second then on again. Removing the plug the relay continues to click on and off for a few cycles, which I don't think it did before.
Left it a few months, then finally got round to taking the back off, and it worked as it should. So I tested various bits and all was well. Then turned it on again, and back to the clicking relay.
I disconnected the main board from the power... -
by max789Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
I made the following tests:
1. Disconnected the main board from Power Board = backlight works.
2. Connected the main board and disconnected the T-Con = backlights does not work.
So I ordered a main board from Ebay also BN41-02156A but from... -
by bpcannan'Morning,
I get sound and picture when powering on the TV and its stays that EXCEPT that the left half of the screen will dim every few seconds then return to normal while the right side of the screen performs as designed.
Did the soft and hard reset options pulling the plug, using the reet option in the vizio menu to no avail.
I checked the mainboard - found some popped capacitors so replaced it - but that did not change the situation.
I checked the t-con board. It is getting good power. Then I removed one ribbon cable to see if I could isolate... -
by jesteraceHi everyone I have this TV which was dead one day when I tried to turn it on. I've had the cover off and there was just a pulsating/electrical clicking/ticking noise from the PSU. I disconnected the mainboard as sometimes this works to just fire it up with backlights on? That didn't help. Same noise. Then I disconnected the backlight cable from the PSU and the TV came alive. It appeared to respond to the remote and i'm pretty sure it's fully operational when there is no backlight connected.
However, I am in a dilemma.
I tested the backlight outputs with the lights disconnected... - Loading...
