Panasonic TX- P42G10E
+ More Options
Posts
  • realfoxx
    • Apr 2016
    • 9
    • Serbia
    Hello to all
    I have Pansonic plasma TX- P42G10E since october 2009. Since couple of weks
    I noted strange changes in picture and sam flickering on motion especially on movie TV channels. It seems the refresh rate is not 100hz,something like that.
    Also there are problems in some background like rings around or twirl, especially when is flashlight on scene.
    There are some pictures of problems:
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Panasonic TX- P42G10E
    I have had some issues out of the mainboards on these sets. This uses the TNPH-0784 board which is prone to developing issues with the Bga solder breaking on the processor Ic's can cause symptoms like this or 14 blink error. Will link my thread if you want. Have you tried resetting the Tv ?
    • realfoxx
      • Apr 2016
      • 9
      • Serbia
      Thanks for the quick answer. Yes, I was resseted and install a new firmware but the problems are there, all is the same.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Hmm maybe take the back off and push on the Bga Ic's see if it improves. You cant really run test patterns on these either as the control board is built into the mainboard so it might still be distorted. Link to my thread:
        https://www.badcaps.net/forum/showthread.php?t=49721
        • realfoxx
          • Apr 2016
          • 9
          • Serbia
          Thanks for link to your thread
          • Andre Gilbert
            by Andre Gilbert
            Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
            Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
            11-20-2024, 08:52 PM
          • jean luc ferre
            laptop hp g72 b52sf screen problems
            by jean luc ferre
            on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
            the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
            i verified the driver of the pΓ©ripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
            i don't understand the reasons of the white stripe at the bottom of the screen below the task...
            06-07-2025, 03:27 PM
          • Hondaman
            USB problems?
            by Hondaman
            Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
            (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
            I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
            08-12-2024, 03:26 PM
          • stecos
            Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
            by stecos
            Hi everyone!
            For my passion for technology I'm now collecting several...
            11-28-2022, 11:39 AM
          • clabr
            Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
            by clabr
            Need help to solve some problems with this laptop.
            After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
            After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
            Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
            Before this had happened I observed some other problems:
            When I tried replacing original mecanical HDD with a SSD HDD could not get them...
            12-02-2021, 08:09 AM
