I was given a Insignia NS-L46X-10A. It works fine for about an hour then the picture slowly solarizes. Takes about 2 hours to completely distort. Does anyone know what would cause this? I'm thinking T con but I've never had this happen. My experience has been solarized at startup. Thanks
Insignia solarized
Tags: None
Re: Insignia solarized
Check and see how hot the Gamma IC gets to be too hot to touch, try cooling it with freeze spray, or use canned air duster upside down for cooling.
Does the Gamma IC have thermal transfer pad on top?Last edited by budm; 04-14-2016, 01:19 PM.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
Tv has been on for 3 hours now but not completely solarized. You can see some barely. The IC has a thermal pad, but not hot at all.Comment
by cajoegHello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV... -
by valvashonI have been going round and round with this one for a couple of years. It's a 16x10 display that allows you to size your OTA picture correctly to 16x9 and that makes it kind of cool so I really want to keep it on my OTA monitoring wall. Accidentially let a screw roll under the powered power supply board and ended up replacing the MOSFET drivers for the inverters, then one of the Schottky rectifiers for one of the supplies, then the PS caps becuase I fired the parts cannon at it one day.
Problem was no cold startup; it would only startup when you applied a heat gun to the board.... -
by valvashonHaving a new problem with the 19" Insignia that I modified with one of my automatic turn on circuits. That is now completely disconnected so that is not the issue. I was doing some modifications on that circuitry and managed to short something out on the underside of the power board.
Actually found and bought the service manual (who knew it was even available?!) which brought me to the High Voltage Startup Circuit controller chip.
Looking up that chip number- LD7575APS brought me to the attached datasheet. I have marked my voltage readings on the schematic sheet (open in new... -
by tbsmithThere is voltage on the bridge rectifier and main caps (163V). Fuses all check good. One of the smaller electrolytic caps (C9112 which is 50V, 100uF) looked bloated, it measured 60uF with one tester, and defective with another. I replaced it temporarily with same uF rating, higher voltage since I don't have the exact one. I also found that one of the switching mosfets (for lower voltage DC supply I think) was shorted. It is a 50R800CE which I didn't have, but had something with the same voltage and current rating and a similar Rds. None of these fixes helped. I'm out of ideas. Any suggestions...1 Photo
by howardc64Eventually discovered a burn mark near lower corner of LCD. Here is a summary
- Backlight on, no image
- Disconnect right buffer board (view from front), left side display comes on
- Masked off pin 7+8 (both ~12,5v on both left and right buffer board) from t-con to right buffer board (view from front) display works but have some lines
- Buffer board is pretty simple
07-11-2025, 04:04 PM - Loading...
