Re: Lg 42 led picture upside down
im not admin just offering you some advise, it maybe also worth starting a new thread in the tv fault finding section as this thread is for lg upside down picture fault, it may get more views and help there just click on the blue new thread part.
this video may help?
https://www.youtube.com/watch?v=eypEiDu__Kw
can we see a picture of the power supply used in this tv so we can look at the led connectorLast edited by vinceroger69; 11-22-2018, 09:06 AM.Leave a comment:
Hi Admin I have a Lg 42Lb550...it came without any Leds in it...someone took it out,I bought some strips ,now I need a pdf or wiring diagram to configure these strip....any help will be appreciatedLeave a comment:
I had a 42” smart LG 42LS575T it had the image upside down paid £35 for it and thought its worth a try, used my phone (Android) and went onto google play store and downloaded an app called “ ANYMOTE “ smart remote app, opened it up once downloaded searched for LG let it do its thing, then you will see
(pic-1) .........
Then grab the right nav arrow on screen and swipe to the left then you get
(pic-2) ........
Then press “EZ-ADJUST” then follow the instructions on this YouTube video passwords vary but (0413) seems common enough
https://youtu.be/56GzjTsdeyg
You may need the normal LG remote.....
all the above is for those like me with no LG service remote...Last edited by comptek; 11-22-2018, 03:50 AM.Leave a comment:
diah a few people lately have downloaded this app and want to use it could you do a guide on how too install it etc as a few threads people are saying they cant connect to their smart tv so maybe there missing a step in the set up of the app etc thanksLeave a comment:
Well done Diah for once good work !Leave a comment:
he used the apk program on android i attached at post 19 to go in service menu and changed the mirror optionLeave a comment:
So you were able to get into the Service Menu and make the Mirror change?
Can you tell us more about the method so that it could help someone else without having to plough through lots of postings.Leave a comment:
Fixed guys the ir app worked amazing thanksLeave a comment:
yes you are right but there much easy and for other led smart tv platform..... here are what you need, it is very easy, just audio or IR with androidYou will need a URC 3940 remote not expensive
Then go here http://openlgtv.org.ru/wiki/index.ph..._menus_/_modes
Works every time for me to access service menus on LG TVsAttached FilesLeave a comment:
Works every time for me to access service menus on LG TVsLast edited by sordids999; 03-31-2016, 04:06 PM.Leave a comment:
looks easy to get into the service mode without a service remote ive just read this and also saw some youtube videos on it but as reece says not sure if it will work but if you have the parts to build one for free maybe give it a try
http://www.hifi-remote.com/forums/viewtopic.php?t=13979Leave a comment:
i used to read from you professional answer,, but not now.Leave a comment:
They do but I know that its not that, I guess you could just flip the Tv upside and and move the logo off the top too the bottom to watch Tv might be cheaper to do haha
do you know why LG put display Mirror Option at engineering menu ?Your mainboard is not set up for that panel properly. You need a board with the EXACT firmware for that EXACT screen. Its not possible to change the screen type in the service menu either as they might have the option for a screen but the firmware to drive it is not kept on the Tv.
of sure not to let you stand on your head to watch TV...lolLeave a comment:
Your mainboard is not set up for that panel properly. You need a board with the EXACT firmware for that EXACT screen. Its not possible to change the screen type in the service menu either as they might have the option for a screen but the firmware to drive it is not kept on the Tv.Last edited by ReeceyBurger123; 03-31-2016, 02:49 PM.Leave a comment:
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by garrymc123Looking for some advice changed over the video input board due to bad hdmi ports but now the picture is upside down tried the service menu but can't find anything to do with flip the picture..
Is there anything I can do to flip the picture or do I need to change the board again..
Garry... -
by ermalsHi all!
I've recently run into an issue with my Samsung UN55H8000AF LED TV displaying no image. I've done quite a bit of research in terms of what could be wrong with it. Below are the steps I've taken prior to reaching out here for some assistance:
1. I've tried replacing the T-Con board (BN95-01594A), twice and have still experienced the same issue with all the boards I've tested with.
2. I've tried to remove one side of the ribbon cable that goes from the T-Con board to the panel and still not getting any image on left or right side.
3. I've checked voltages... -
by SoulzinkHi everyone,
I am trying to fix a samsung washinmachine power supply main board.
I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
The power supply board reference is the following: DC41-00189a
I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel... - Loading...
