Emerson LF401EM5 won't turn on; red standby light stays on.
  • seaspur
    • Mar 2016
    • 7
    Good evening- I have a TV that suddenly will not power on. Emerson LF401EM5. I have done quite a bit of internet research on the issue to no avail, so I turn to you all for guidance. The TV was purchased about 10 months ago and we don't have reciept (only "proof" of purchase on bank statement unfortunately).
    Essentially, I have red standby light on when the TV is plugged in. The remote power button nor the button on the TV will power on the TV.
    That red light does not flash. It also stays on about 10 seconds after unplugged, if that information is helpful.
    I took the panel off to inspect the board with my limited knowledge. I didn't see any "raised/poofy" transistors nor anything that looked out of ordinary. I also didn't see a fuse at all- I noticed many people online seem to fix their TV power issues by replacing fuses. Maybe some don't have them?
    I own a multimeter but have zero experience or tools soldering.
    I researched issues where many people had flashing red lights or beeping noises, but exactly doesn't fit my problem description.
    Essentially, I want to know how much a repair would cost and if it is economically wise to do so. I paid about $200 for this TV set, but still- it was only a little under a year ago...so I'd like to revive if possible.
    Thank you all in advance!
    Re: Emerson LF401EM5 won't turn on; red standby light stays on.
    We will need good clear pictures of the whole backside of the TV so we can see all the boards.
    Here are some of the boards used in your TV if they matched what you have.
    http://www.shopjimmy.com/catalogsear...erson+LF401EM5
    • CapLeaker
      Leaking Member
      • 8214
      sounds like an EEPROM issue. There is one available from SJ.
      http://www.shopjimmy.com/emerson-lf4...eprom-only.htm
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Agree firmware/Spi flash fault. Norcal has a vid on the 46" version stuck in standby was failed firmware. Check the Pson and Bl on signals to confirm.
        • seaspur
          • Mar 2016
          • 7
          I have attached a photo of each board for your review.
          Thanks again.
          • seaspur
            • Mar 2016
            • 7
            I'm sorry, could you dumb these comments down/explain a little as to what has occurred?
            Also, I looked at the link for that "EEPROM". I see something near the CPU(?) that looks similar- how does it get installed/replaced and what is it's function? I'm assuming soldering, which I have zero experience/tools for. Maybe I could find a friend, though, if necessary?
            If a failed firmware happened, is there a way to manipulate the TV with something from a USB drive? Like a rollback or forced update?
            • seaspur
              • Mar 2016
              • 7
              Also, I found an eBay seller with the same board "BA4AT0G0201 3" out of a TV with broken screen for sale at $20. Would it be worth me doing that over replacing the EEPROM for $15? That route would only involve screwing it on and inserting cables, correct?
              • CapLeaker
                Leaking Member
                • 8214
                Changing that EEPROM isn't that easy. So if you feel more comfortable changing out the mainboard instead, do that.
                • seaspur
                  • Mar 2016
                  • 7
                  Thank you. I will order and update after I install. Please inform me of any precautions I should take before attempting.
                  I appreciate how responsive this forum is.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Also some advise after you replace mobo. Stop turning the Tv on and off ! Lol what I really mean is power cycle it less as the Spi flash or as CL referred to it as an epprom power cycling it more often wears it out faster so watch it for a good few hours at a time before turning it off.
                    • seaspur
                      • Mar 2016
                      • 7
                      So the mobo I ordered came in and ended up being slightly different part number (listing title was wrong). I installed anyways and everything is working now!
                      Thank you all for your assistance.
                      Last question: should I do a software upgrade on this TV? I have this feeling like it is delicate now and I'd hate to do anything that would damage it again.
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Awesome, maybe do a software update if you want
                        • CapLeaker
                          Leaking Member
                          • 8214
                          Good to hear!
                          • ChristianBr01
                            LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                            by ChristianBr01
                            I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                            The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                            What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                            04-23-2025, 01:48 AM
                          • Jackching
                            Samsung UN46EH5000F wont turn on. Blinks red standby light continuously
                            by Jackching
                            I know for sure it has a bad cap and one cold solder joint. Just wondering before i order the Caps if anyone has any experience with this model? Just making sure there isnt a common component that goes bad besides the caps....
                            04-15-2024, 05:14 PM
                          • PNI E.
                            Samsung ue55tu7170u not turn on and no standby led main bn9650990e
                            by PNI E.
                            Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
                            03-17-2025, 04:23 AM
                          • Kaar3l
                            Samsung QLED QE65Q7FNAT only standby light
                            by Kaar3l
                            TV: Samsung QLED QE65Q7FNAT
                            PSU: BN4400940A
                            MB: BN94-12832K
                            I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                            09-24-2024, 01:35 PM
                          • jasonbay13
                            Philips 37HFL5682L/F7 no standby light, incomplete service manual?
                            by jasonbay13
                            picked up a tv and when the power is plugged, the standby light flashes real quick then goes off. of 3.3, 12, 24v is all there but i couldnt find any 5v on the back-end board. ON/OFF is low, which it seems is what turns on the backlight so i removed the wire at the back-end board and put a 10k resistor to the 3.3v, which when plugged in brings on the backlight for a split second and also a blue light "LED1" on the inverter board, which goes off after a short time.
                            am i missing something to bring on the backlight or is the inverter/ccfl gone bad? would that cause the inverter board...
                            12-01-2023, 09:55 PM
