Samsung PN64D7000 Plasma - Sound but no picture
  • retro12345
    • Mar 2016
    • 13
    Started occurring randomly and was fixed by unplugging power and replugging it back. Slow blinking green light from the logic board. Read a few of the threads online and changed out the Y Main board from a board I bought on Ebay. It worked fine for a 2 hour movie, but then I mounted the TV back on the wall, and it happened again the very next night. Before I but any other boards like the Y buffer or X main, I would like advice on troubleshooting that I can perform with my Meter with your guidance. I am a newb, but also understand the dangers of the voltage going through the box. Here are the pictures of the boards in the box and also of my meter. Is that set to the correct settings for measurement, and what sections of the board should I test for troubleshooting.
    Thanks Friends!
  • Nick's Tvs
    • Jan 2014
    • 621
    Re: Samsung PN64D7000 Plasma - Sound but no picture
    Sounds like a typical cracked solder joint if you ask me. Check the back of your power supply board, and both your Y and X-sustain.
    Check all components, and heat sinks.
    • retro12345
      • Mar 2016
      • 13
      Just to follow up on this for anyone else experiencing the issue. I bought a new y main board from eBay; screen worked normally but then experienced same issue. Bought new power supply board from shopjimmy, and now it works again.
      Retro
      • ljintexas
        LJinTexas
        • Jan 2015
        • 669
        I agree Nick. I have fixed many mysterious issues by resoldering all major power passing devices on smps, y and x boards.
        • Fleckers tv
          Fleckers TV
          • Nov 2015
          • 89
          I had the same problem , it'. Was the voltage regulator on the PCb chucking out 7v instead of 13v. Replaced the reg and all was ok .
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            You need to check the Vson signal which tells the Psu to turn on the rails that drive the sustain boards.
            • rl2009
              • Sep 2009
              Have the exact same problem. Anyone out there have some service manual or schematics you could share? Cannot find these anywhere. Replacing a regulator would be a wonderful trick, but need to narrow it down a bit in terms which regulator to check. The only service information I found so far is this
              http://www.toms-service-manuals.com/index.php?do=search&mfg=Samsung&modelsrch=PN64D7000FFXZA&typekey=0&Search=Submit
              These are much better than nothing, but not quite detailed down to specific regulators.
              Thanks,
              • TR103
                by TR103
                - it keeps rebooting
                01-22-2025, 04:12 PM
              • Mgiffune
                by Mgiffune
                06-09-2024, 10:28 AM
              • Ierwin
                by Ierwin
                05-13-2025, 03:31 PM
              • jchang
                Samsung UN70NU6900F no picture and no sound
                by jchang
                Hi all
                I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                Symptom:
                No picture no sound.
                When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                No sound at all.
                What I tried:
                1. I tried unplugging the left or right ribbon...
                01-09-2023, 06:28 PM
              • Dodgethis
                Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                by Dodgethis
                Hello all,
                This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                09-11-2024, 07:39 AM
