LG 50PB560B-UA Sound no video
  • smuddge
    • Feb 2012
    • 96
    Don't see anything wrong with any of the boards. The tv is very clean and has had very minimal use.
    looking for some guidance or if someone has had the same problem with this particular tv.
    pics of all boards attached.
    I have a multimeter but I do not know what I should be looking at.
  • mmartell
    • Oct 2013
    • 3189
    Re: LG 50PB560B-UA Sound no video
    Post your pics in line by using "Manage Attachments"
    • CapLeaker
      Leaking Member
      • 8220
      also need another pic from the whole back side of the TV to see how everything is connected.
      But having backlight and sound, but no picture... sounds awefully like a TCon board. So check it if it has proper voltage on both sides of the fuse(s).
      • vinceroger69
        • Mar 2012
        • 6714
        is this a plasma?
        • cliff_hootarski
          • Jul 2006
          • 411
          Plazma, yes. Look at the Power Supply board, you can see Va and Vs test points labeled.
          • vinceroger69
            • Mar 2012
            • 6714
            I was just confirming, as post 3 about t con fuse the op maybe looking for one that this set does not have ( its a easy mistake to make as i skim read threads too at times) im not sure on a lg if you can run the test patterns via the control board etc.
            • Nick's Tvs
              • Jan 2014
              • 621
              Test pattern on lg yes, its been done.
              • Hamie
                • Apr 2014
                • 1383
                Due to the fact ive seen dozens of these sets im going to say faulty y-sus. Should be easy to repair as its probably failed the same as the all the rest.
                • smuddge
                  • Feb 2012
                  • 96
                  yes plasma. sorry i forgot to ad that.
                  is the ysus built into the ybuffer on this board?
                  if so what part on this would I be replacing?
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    yes im pretty sure it is not sure what common parts go though maybe look for the board number on your ysus and look what parts are in the repair kits and start testing them.
                    • Hamie
                      • Apr 2014
                      • 1383
                      Can you post the voltages for -vy and vsc.
                      • mmartell
                        • Oct 2013
                        • 3189
                        Well that's a sparse looking plasma. The ysus is integrated with the buffers - or vice versa lol
                        • Ltank
                          • Jun 2013
                          • 776
                          I have one of these sets. I am sure the main board is bad. EBT62854104
                          The P.S. EAY63168601 has VS of 201 and VA of 55 and has the 5ndc and 17vdc. The P.S turns on with or without the M.B. attached. I did not see a PS-on command label on P.S. I wanted to make sure it works properly. T Control board EBR7714501 does not have a test pattern jumper that I can find or solder a jumper to, to be sure the panel is good.
                          How do I create a test pattern ?
                          thanks
                          • Ltank
                            • Jun 2013
                            • 776
                            I tried uploading pics from phone but no luck.
                            Do I jumper the two pads between IC704 and R451 and R452? Reference to the above pic of the control boad?
                            • NasTech
                              • Sep 2011
                              • 58
                              I have the same model with sound no display. From the voltage reading i have done i think my problem is the z-sus board. The power supply voltages are good but the z-sus voltage are good except P132 pin 1 only reads 3.7v and it's mark 18V even when I disconnect the y-sus connector it still reads 3.7v
                              • Hamie
                                • Apr 2014
                                • 1383
                                It's probably not your z sus that's at fault. Its the y-sus.
                                Take a picture of it.
                                • NasTech
                                  • Sep 2011
                                  • 58
                                  I discounted connection P132 the runs to the y-sus board to see if it is pulling down the 18v on the P132 pin 1 but it still reads 3.7v. Which section of the z-sus board produces this 18v supply?
                                  • matador777
                                    • Nov 2015
                                    • california
                                    • Buddydog
                                      • Jan 2019
                                      First time posting I'm looking for a part number on a lg50pb560b main board. Q604. Not sure if it's 7aw46 or 7bw46. Thanks
                                      • soeren
                                        A2442 - No sound over internal speakers and no video playback
                                        by soeren
                                        I am facing a strange issue, I don't have any sound over my internal MacBook speakers and also the video won't start. If I change to my head speaker or via HDMI (speaker on my external Display) the sound works over the head speaker or Display and also the video starts (ex. youtube).
                                        All happened after the battery ran out of power overall several days when I was on vacation.
                                        I tried to remove the battery and then reconnected the battery, and then the MacBook Pro 14 2021 won't accept any power from my power socket. Then I removed one speaker, connected again the battery...
                                        07-26-2024, 01:24 AM
                                      • JRade
                                        Audio video receiver KENWood KR-V990D,no sound
                                        by JRade
                                        When I select the FM receiver, I find a radio station, the sound is heard on REC OUT(L,R), REC TAPE1(L,R),REC TAPE2(L,R) on high-ohm headphones, the sound regulation does not work.
                                        The output reacts when I connect the record player to PRE OUT FRONT L, the sound is heard in the speaker but the sound regulation does not work. Then it does not matter what I chose on the front selector.
                                        I replaced the capacitor C303/0.047F, nothing changes.
                                        I'm asking for help, what should I do next?
                                        Thanks in advance!...
                                        08-05-2025, 10:23 PM
                                      • FrancescoV
                                        Onkyo HT-R390 no sound output, video output ok
                                        by FrancescoV
                                        Good morning everyone,
                                        I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                                        The firmware reported is the following:
                                        M:1.00/11107BLP
                                        D:?.??/????????
                                        O:1.00/11107AL
                                        The DSP firmware given the question marks seems corrupt.
                                        On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                                        05-11-2025, 02:59 AM
                                        HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                                        This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                                        09-12-2024, 02:00 PM
                                      • LEECH666
                                        Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                        by LEECH666
                                        Good day ladies and gentleman!
                                        I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                        This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                        I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                        01-19-2024, 05:46 PM
