LC42SV50U Won't Turn On
  • burner6999
    • 89
    I am having trouble with a tv that I picked up to fix and give to a friend for his birthday. I have power to the supply. I also have power coming out. There is no lights or anything that come on when it is plugged in. I have tested all the voltages and have listed them in the picture. If I put 5v to the brown wire on the left, then the backlights come on. I have also purchased the service manual for the tv in hopes to fix it. Is there anything else that I can check? I cannot find a main board anywhere, but it looks like it is the culprit at this point. I have also tested the power at the switch that turns it on. the is a ground, and two other wires that have 3.3v then when the power is pushed one drops to 0v. I am not sure why the standby led does not light when it is plugged in either. I can't get pictures of the actual board right now, but nothing looks different then in the pictures. No bulging caps or anything burt.
  • tech2014
    • Aug 2014
    • 807
    Re: LC42SV50U Won't Turn On
    do you have standby voltage? If you have no power LED lit that usually means you are missing standby.
    • burner6999
      • 89
      I am not sure there is hardly any markings on the board. Where would I check for that?
        It looks to me you do have standby Voltage and you also have the PS-ON command signal to turn on the 12V and the 24V power supply but you are missing the BL-ON signal to turn on the backlights circuits.
        Where is the picture of the backlghts Inverter board?
        • burner6999
          • 89
          I didn't include it because it was all working. If I put 5v to the brown wire the backlights come on.
            So the brown wire is the BL-ON pin, you will have to troubleshoot the main board next then to find out why the BL-ON is missing, and since you can force on the backlihts and if all other function of the main board is OK then you should see pictures on the screen if not then you have more than just BL-ON control signal problem.
            • burner6999
              • 89
              There is a reed LED at the bottom of the tv that is supposed to light up when the tv is plugged in but it doesn't either.
              Any help on where to start with the main board.
              • ljintexas
                LJinTexas
                • Jan 2015
                • 669
                PTS Electronics will repair and return your main board.
                • dick_barton
                  • Aug 2015
                  • 6642
                  • Wales
                  There's another thread on here which could be helpful
                  https://www.badcaps.net/forum/showthread.php?p=555792
                  • CapLeaker
                    Leaking Member
                    • 8116
                    looks like you need a new main board if that file doesn't work.
                    • burner6999
                      • 89
                      I saw that post already, but the usb doesn't seem to have any power. What would happen if I put >>>>>this board<<<<< in it? It looks identical in every way.
                      • CapLeaker
                        Leaking Member
                        • 8116
                        It may work, but you have to set the panel up in the service menu, since the board is for a different screen size.
                        • burner6999
                          • 89
                          Is this something you have done before?
                          • CapLeaker
                            Leaking Member
                            • 8116
                            I've done it before. The hard part is you need to find a compatible main board, that supports the panel you have.
                            Lets say some support from 32" to 42" others from 46" to 50 something.
                            Either someone on here already knows what main board is compatible, or you have to do some research.
                            • PNI E.
                              Samsung ue55tu7170u not turn on and no standby led main bn9650990e
                              by PNI E.
                              Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
                              03-17-2025, 04:23 AM
                            • madsox
                              Harman Kardon AVR 171S - standby led lights up, does not turn on
                              by madsox
                              Greetings!
                              Thank you in advance for your understanding, I am writing to you through a translator.
                              A Harman Kardon AVR171S amplifier was given.
                              The history of the machine is as follows:
                              It was faulty when I bought it, I want to fix it.
                              I replaced the HDMI switch and one of the DAC ICs in it.
                              After that it worked without a problem.
                              I watched a movie using the amplifier, and at the end the amplifier got really hot.
                              The cooling was faulty, I will fix this later.
                              I switched it to standby mode, waited for...
                              09-24-2022, 10:46 AM
                            • tvguy12012012120
                              by tvguy12012012120
                              02-07-2025, 05:13 PM
                            • julianmustofa
                              Asus x453ma only turn on when plugged in (battery was fine)
                              by julianmustofa
                              Hi all
                              Iv'e been working on asus x453ma that only turn on when the ac adapter connected
                              The battery itself was fine
                              So this is what happen
                              -plugged ac adapter
                              -trigger power button
                              -laptop turning on
                              -unplug the ac adapter
                              Laptop still on with battery
                              -without ac adapter
                              And nothing happens
                              Have no idea what is going on
                              Charging sistem still works when laptop is turning on
                              And also when battery reach 100% the charging indicator still red. It should turn white/green...
                              10-18-2023, 01:48 PM
                            • pajdek
                              Lenovo Y700-17ISK turn on and off
                              by pajdek
                              Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                              09-20-2023, 02:49 AM
