Panasonic dp42d23
+ More Options
Posts
  • superbob8
    • Mar 2016
    • 21
    Panasonic dp42d23
    Hi
    I have a tv with a blank blue screen and no sound can you help troubleshoot the issues .I am posting some pics also
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Panasonic dp42d23
    Do you have a DMM ? Also checked the Tcon fuse ?
    • superbob8
      • Mar 2016
      • 21
      I have not checked the tcon fuse where exactly is it located ? I do not see any fuses on any of the cards ?
      • martyparish
        • Dec 2012
        • 313
        The title says Panasonic but the tag on the back says Sanyo.
        Picture #3 is the tcon. The small white smd part with gold ends(near connector) appears to be the fuse.
        Picture #4(the main board) it appears that the ribbon cable is not all the way in. Check that for sure.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Sanyo was a part of Panasonic but they sold the brand off very fast to other cheaper oems.
          • superbob8
            • Mar 2016
            • 21
            Hi Marty
            The fuse has continuity ( I guess I am used to easily replaceable fuses and the connector is in all the way what else can I check and what board usually creates these symptoms where it is a blank blue screen and no sound and nothing else ?
            • superbob8
              • Mar 2016
              • 21
              yes and I tested the fuse on the tcon could it be the board ?
              • martyparish
                • Dec 2012
                • 313
                Have you tested all the pins on the power board connector? Make sure that the 5v and 12v rails are correct.
                Also, test that tcon fuse while tv is on to see if power exists.
                Is the on screen display available? (press menu btn)
                • martyparish
                  • Dec 2012
                  • 313
                  I'm not keen on throwing parts at a tv, but dang these parts are cheap! ($32 main, $8.50 tcon on usa ebay)
                  • superbob8
                    • Mar 2016
                    • 21
                    Hi Marty
                    thanks for the help
                    no the screen does not show the menu
                    how do I test that the 5 and 12v rails -where are the test points
                    • superbob8
                      • Mar 2016
                      • 21
                      Hi Marty I bought the tcon board from ebay and would that give me a blue screen if it was defective ?
                      • martyparish
                        • Dec 2012
                        • 313
                        I would have done the voltage tests first before ordering.
                        For power supply: Test the pins on the connector that go from psu to main board. The pins are labeled.
                        For tcon: measure the voltage on both sides of the fuse while set is on.
                        For both measurements, use the metal chassis of the tv for ground.
                        I was leaning towards main board failure but never know...
                        • superbob8
                          • Mar 2016
                          • 21
                          Hi Marty
                          where can I get a schematic for the dp42d23 sanyo or panasonic tv ?
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            HTML Code:
                            What was the fault prior to changing the TCon board?
                            • superbob8
                              • Mar 2016
                              • 21
                              Hi Dick
                              the screen is blue and pressing input will not do anything I changed the Tcon board but I still have the same symptoms ?
                              • Alastair E
                                Chief Womble
                                • Mar 2013
                                • 1963
                                • U.K.
                                With all PSU supplies OK, It'll be Mainboard issue or the panel itself...
                                --Unless of course, You fitted a similarly faulty T-Con!
                                TELEFIX
                                • martino
                                  Not so "senior"
                                  • Aug 2013
                                  • 997
                                  • canada
                                  Did you try disconnecting one of the ribbon cables at the T-con? The white ones that go from t-con to panel?
                                  Disconnect left ribbon,try tv,reconnect left and disconnect right one. See if you get a halve screen on one of those.
                                  Proud owner of dozens of broken TV's and many,many,many boards.
                                  Our website and passion:http://hollenhundshepherds.com/
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    Have you tested the power supply as martyparish has previously suggested and what dc voltages do you get?
                                    • superbob8
                                      • Mar 2016
                                      • 21
                                      Hi
                                      I measured the terminal and the 5 vdc were present but no 12 vdc was to be found
                                      so what could be causing the 12 v to not be present ?
                                      • dick_barton
                                        • Aug 2015
                                        • 6643
                                        • Wales
                                        Hello superbob8
                                        In order to help you and without the TV in front of us and having now previous knowledge of the TV you need to provide as much information as possible.
                                        The connector I highlighted, can you list the names of the pins and what voltages are on each of them in turn. The name of the pins are written above the connector but I cannot make them out from you picture.
                                        If you have 5v but not 12v then we need to know what voltages are on those pins. Please can you list all the pin names and what voltage you read alongside the name so as to give us a clue if it is a mainboard or power supply fault.
                                        • Chrissygizmo
                                          Panasonic TX-48CX350B backlights but white screen , blank screen
                                          by Chrissygizmo
                                          Hi all, I’ve got a problem I hope someone can help me fixi.
                                          I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
                                          01-11-2025, 03:18 PM
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                          11-20-2024, 08:52 PM
                                        • hasel17
                                          CH341a can erase and read but can't write and blank check
                                          by hasel17
                                          So I am trying to repair broken thunderbolt FW on X1 Yoga Gen 2. The EEPROM chip is WINBOND 25Q80DVNIG. I already do a back-up and erase. But when I try to wrote new FW, it was successfull, but when I tried to read it, it still blank. when I try to do a blank check, it gave me instant error in address 0. I already tried two CH341A, already did the 3.3v fix mod, using AsProgrammer, NeoProgrammer, Colibri, and CH341A 1.29. But the problem still occurred. What I did wrong here? Can anyone help me? Thanks in advance. Here is the log in Colibri :
                                          Code:
                                          Checking for blank...
                                          (Press
                                          10-26-2023, 06:20 AM
                                        • AquaMan Ua
                                          by AquaMan Ua
                                          05-17-2025, 09:40 AM
                                        • kotel studios
                                          Funai 32FL553P/10 - squealing from PSU, dies after 10 seconds, blank screen after logo, bootloops
                                          by kotel studios
                                          Found an Funai 32FL553P/10 TV on sale for cheap listed as broken, so I decided to give a shot at reparing this.
                                          State I got it in:
                                          Squealing from the PSU
                                          After logo I get a blank screen
                                          After 10 seconds of having a blank display w/ backlight the TV dies
                                          Give it 7-10ish seconds again and it starts to bootloop.
                                          What I did so far:
                                          Replaced all the caps on the PSU (apart from primaries, they were fine and none at hand)
                                          Checked all voltage rails:
                                          5VSB - 4.8V
                                          AMP+13V - 14.4V
                                          13V - 12.98V (in manual 12V)...
                                          09-21-2025, 02:00 AM
