Lg 50pc3d psu
  • Malachi
    • Dec 2015
    • 1077
    • Usa
    Lg 50pc3d psu
    I have this psu that has bulging leaking capacitors.
    I went to mouser to look some up to purchase.
    They are 10v 3300uf. I selected the Panasonic brand because I read in the forum here that they are a good brand, but there is more than one type.
    I don't know which kind it needs.
    Could I get some advice?
    I thought at one time I had seen a sticky about recommended brands but can't find it.
    I found the sticky and I see rubycon is the top one. the caps are about 24mm tall and about 12 mm in diameter.
    Would this work? CAP ALUM 3300UF 20% 10V RADIAL
    The difference seems to be something called ripple current and impedance.
  • RCA2000
    • Sep 2014
    • 111
    Re: Lg 50pc3d psu
    Well I would get a 16V 105C cap to replace the old ones. Should NOT be trouble fitting them
    DO NOT--get 85C caps...they DO NOT last in flat sats..or for that matter standard CRT sets too well either...
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Re: Lg 50pc3d psu
      Why go 16v ? The old ones on them are a common fault to fail which is not due to them being 10v rated. You should use the Panasonic FR series which will work great on that Psu. Replace any other that cap that is branded by Samwha with the Wb or Wl series.
      • Malachi
        • Dec 2015
        • 1077
        • Usa
        Re: Lg 50pc3d psu
        I don't think I can do it myself. Someone offered to do it for $50 if I supply the parts.
        Panasonic fr for the 10v 3300uf and Panasonic Wb or Wi series for all the others?
        • Oldschool297
          RELAND SUN 6.3v 3300uf Low or High ESR?
          by Oldschool297
          I found these, i would only like to try them on a board to see if it post. It don't post at the moment, i guess there are 9 6.3v 3300uf that can be broken. Is these low or high esr? I did not find info on the web.
          https://www.amazon.de/-/en/10-Capaci...s%2C469&sr=8-1
          08-14-2023, 04:32 AM
        • TomGJ
          Genelec 8020C Bad capacitor
          by TomGJ
          Hi All, So I have two Genelec 8020Cs that are about 10 years old, one of them stopped switching on. I took it apart, fuse was blown, and I've traced the short to one of the two large capacitors on the circuit board.
          Now from looking at the Capacitors, they seem to be from Samwha's SD Series with the following specs: 3300uf, 35v, 85C, 25 x 16 mm Radial.
          The problem is, I can't find any capacitor from Samwha's SD Datasheet that matches these specs. The closest is 3300uf, 35v, 85c but 31.5 x 16mm, with a max ripple current of 2.5A. I'm guessing the 25mm is custom made for...
          11-02-2024, 07:45 AM
        • Satdude
          2700uF instead of 3300uF
          by Satdude
          Hey guys, I have a question. I need to replace the caps on my og Xbox motherboard, but I can't buy quality capacitors in my country with this specification (everything is either out of stock, with a minimum order of 1000 or just plain too big to fit in the Xbox). Can I replace the 5 3300uF caps with 5 Panasonic 2700uF caps? Thanks
          02-12-2023, 06:23 PM
        • randmusr
          Randmusr's 2000-2003 radial replacement thread *pic overload*
          by randmusr
          Soltek SL-865G 775
          6x 3300uf 6.3v
          I realize now I could have polymodded this. But @ 3x the cost of these FR these will do!
          11-21-2024, 08:00 PM
        • EFritz20
          Available replacements Rubycon MBZ 3300uf 6.3v low ESR?
          by EFritz20
          I have a few busted Rubycons MBZ 3300uf 6.3v that are used for VRM purposes on a socket A motherboard. According to spec 12 mOhm with 2800 ripple.
          I have used the search engine and it appears the Panasonics are the ones to get, but those are topics already years old and these electronic ultra low ESR caps aren't availably anymore .
          I can't seem to find any available caps on the known sites that are in spec of these Rubycons. Also i can't find Polymers with 3300uf or even close to that. Closest ones i found where 2000/2200uf ones but...
          05-20-2021, 10:22 AM
