Sony KDL-46X4500 - 6 LED Blink Code
  • AlbertRoss
    • Jul 2012
    • 181
    • United Kingdom
    Hi, have a Sony KDL-46X4500 with a 6 LED blink code, no picture or sound. So far, only checked STB voltage, which is 03.37V. There are no other voltages on same connector as STB?
    Did a quick google and found that the 6 LED code could be either the main board, power supply board or inverter boards, not sure which one or what to check next? Thanks.
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: Sony KDL-46X4500 - 6 LED Blink Code
    Picture 2 , the blue capacitor/coil? ( with the black dot showing negative side ). Cant really see what it is. It looks like a swollen cap?
    What brand of caps are in that psu?
    • AlbertRoss
      • Jul 2012
      • 181
      • United Kingdom
      The blue capacitor/coil, as far as I can see is TOKIN R7? Seems as if the capacitors are all Rubycon?
      • AlbertRoss
        • Jul 2012
        • 181
        • United Kingdom
        Can you check these type of capacitor/coils using a ESR meter, if so, I obtain - in circuit/leaking, ESR 1.87 ohms?
        • AlbertRoss
          • Jul 2012
          • 181
          • United Kingdom
          Removed NEC/TOKIN 4 R 7 capacitor/coil from board and checked with ESR70. Reads same either way around.
            That is an inductor for the pi filter.
            You have problem in the inverter circuit. You do need to make sure you do have boosted Volatge of around 400Vdc to run the inverter section, also need to check fusible resistor that feeds the 400Vdc to run the inverter circuit.
            • AlbertRoss
              • Jul 2012
              • 181
              • United Kingdom
              When TV on standby (red led) I obtain 395.0 VDC, switch on TV, green led stays on momentary and then changes to red 6 led blink code, at this point I have a reading of 328.5 VDC?
              • CapLeaker
                Leaking Member
                • 8263
                328.5V means the PFC is off, no boosted voltage, no power for the inverter.
                395V means the PFC is running and you have PSon signal and the STBY voltage is there too. So the inverter should get sufficient power, from the power supply. Next check the BLon pin to see if the inverter gets turned on too.
                • AlbertRoss
                  • Jul 2012
                  • 181
                  • United Kingdom
                  Only had around 3.35 VDC on BLon pin for about 2 seconds when TV switched on, then went in to blink code? What I did notice was, the SONY logo on the center front panel lit up momentary?
                  • CapLeaker
                    Leaking Member
                    • 8263
                    Measure up the all pins on the connector and report back with the pin out name and voltages measured.
                    Sounds like an inverter problem.
                    • AlbertRoss
                      • Jul 2012
                      • 181
                      • United Kingdom
                      HVR - Not Used
                      DIMMER - 01.04V
                      B/L_On - -00.06V
                      INV_ERR - 00.00V
                      BALLANCER_ERR - 00.00V
                      POWER_ON 00.00V
                      AC_OFF_DET - 3.13V
                      STB - 3.37V
                      REG12V_GND - 00.00V
                      REG12V_GND - 00.00V
                      REG12V_GND - 00.00V
                      REG12V - 00.00V
                      REG12V - 00.00V
                      REG12V - 00.00V
                      • CapLeaker
                        Leaking Member
                        • 8263
                        That's with the TV off, you have to catch it in that 2 second on time frame.
                        • AlbertRoss
                          • Jul 2012
                          • 181
                          • United Kingdom
                          So I have to take the readings again before the TV goes in to blink mode?
                          • AlbertRoss
                            • Jul 2012
                            • 181
                            • United Kingdom
                            Readings taken just before TV goes in to blink mode:
                            HVR - N/U
                            DIMMER - 00.98V
                            B/L_ON - 01.00V
                            INV_ERR - 00.00V
                            POWER_ON - 03.31V
                            AC_OFF_DET - 03.13V
                            STB - 03.37V
                            REG12V_GND - 00.00V
                            REG12V_GND - 00.00V
                            REG12V_GND - 00.00V
                            REG12V - 11.98V
                            REG12V - 11.97V
                            REG12V - 11.98V
                            • CapLeaker
                              Leaking Member
                              • 8263
                              BLon sitting at 1V isn't enough to turn the backlights on. I should have more than 2V.
                              So you may have to do following:
                              Unplug TV. Remove the BLon pin out of the plug that comes from the main board back to the power supply (we dont want to feed back power). Next solder a 1k resistor from STB to BLon on the powe supply. Plug the TV back in and turn it on and check those voltages again.
                              • AlbertRoss
                                • Jul 2012
                                • 181
                                • United Kingdom
                                Ok, thanks, will do first thing tomorrow!
                                • AlbertRoss
                                  • Jul 2012
                                  • 181
                                  • United Kingdom
                                  Removed BLon terminal from plug to main board, soldered 1K resistor from STB (rear of board) across to BLon. TV on - 03.37V, after a couple of seconds, TV went in to blink mode, voltage dropped momentary but then went back up to 03.38V.
                                  • AlbertRoss
                                    • Jul 2012
                                    • 181
                                    • United Kingdom
                                    I have now checked all voltages again because before I had 00.00V on INV_ERR. With TV on (green LED) I have 00.00V, just a split second before TV goes in to blink mode I get a voltage of 03.08V but then drops to 00.00V?
                                    • CapLeaker
                                      Leaking Member
                                      • 8263
                                      When the TV is on with a green LED, you have 0V on the INV_ERR pin.
                                      But then there is a short blip to 3.08V and the main board goes to blinking? No backlights for 2 seconds or something?
                                      • AlbertRoss
                                        • Jul 2012
                                        • 181
                                        • United Kingdom
                                        Almost, just tried it again.
                                        Power cable connected to wall outlet and TV, switch on wall outlet (00.00V) turn on TV with panel switch, green LED shows on front panel, approx. 6 seconds later with green LED light still on, the voltage drops to 00.00V. It does this just before the TV enters blink code?
                                        Have never seen the backlights work, also no sound or picture?
                                        • cloo
                                          Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                          by cloo
                                          I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                          It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                          So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                          After doing a factory reset this problem was gone and the picture was back to...
                                          01-06-2025, 06:02 AM
                                        • reporter1979
                                          2 red blink code on old led tv Sony KDL-40W2000
                                          by reporter1979
                                          Hi all, the TV KDL-40W2000 was flashed by a lightning.
                                          Firstly I got the 3 red blink code.
                                          Following other threads I changed the power supply board and got always 3 blinks.
                                          So I changed also the mainboard and now I get 2 blinks error code. Tried also with the other ps board, still getting 2 blinks.
                                          The TV turns on for a minute or two with green led and blank screen, if I press buttons the green led blinks fast. It turns to 2 red blinking led after a while.
                                          What else can I do?...
                                          02-17-2023, 11:50 AM
                                          LCD LED TV Service Menu Codes
                                          ALL LCD LED TV SERVICE MENU CODES
                                          Service Menu Code with Board Name
                                          China Universal Board / Jumper Board Service Menu Code
                                          Changhong Ruba Service Menu Code
                                          Ecostar LED TV Service Menu Code
                                          Orient LED TV Service Menu Code
                                          Haier LED TV Service Menu Code
                                          TCL LED TV Service Menu Code
                                          Samsung LED TV Service Menu Code
                                          LG LED TV Service Menu Code
                                          Videocon LED TV Service Menu Code
                                          Supra LED TV Service Menu Code
                                          Toshiba LED TV Service Menu Code
                                          Symphony LED TV Service Menu Code
                                          Veste/ LED TV Service Menu Code...
                                          10-31-2024, 03:58 AM
                                        • Storyteller12
                                          Sony XBR-65X900E 4 Blink Code
                                          by Storyteller12
                                          I have this set. It turns on and is watchable for a few minutes but then shuts off and flashes 4 red lights.
                                          I don't work on Sony much but assumed it was backlights from what I read.
                                          Opened up the TV and tested all the backlights with led tester and the all work.
                                          I know sometimes that doesn't mean anything since it's not running at full current but I hate to spend $120 on backlights (shopjimmy) is the only one that even has them just to find out I missed something.
                                          So anyway to test these lights similar to the way we test...
                                          12-31-2022, 02:17 PM
                                        • rmacintosh
                                          Panasonic Plasma repair - TH-P60GT50 - Dead, 3 blink code
                                          by rmacintosh
                                          I aquired this Panasonic 60" plasma around the time my first child was born. It was meant to be a project tv, hoping to fix it chipping away at the repair in my free time. Well that was 2 years ago and i'm really just getting around to making a sincere effort to see if I can ressurect this beast.
                                          The symptoms of the tv ar as follows:
                                          • Plug AC in to back of TV
                                          • After about 2 seconds the relay on the P-sub board will click on and then a fraction of a second later it clicks back off
                                          • The 3 blink code is given by the power LED
                                          • If the TV is unplugged and then
                                          03-14-2020, 12:24 AM
