17pw26-4
+ More Options
Posts
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: 17pw26-4
    You know how you tested the fuse ? Your meter beeps if its good, same with a shorted component if a part is shorted your meter will beep when you probe the legs of a device. To test the fets go up and down the board in diode mode and probe the pins of each fet.
    • charlierfc
      • Mar 2013
      • 93
      • scotland
      Re: 17pw26-4
      thanks reeceyburger. will give that a try, need to head out now, i noticed it was a bit discoloured underside near the ones at the top, so ill guess thats the ones to start with
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Re: 17pw26-4
        Glad to help, normally the top ones that blow hopefully they did not take out the resistors too if so not going to be easy.
        • vinceroger69
          • Mar 2012
          • 6714
          Re: 17pw26-4
          i wonder if its worth also replacing that controller ic SEM2017 Ic as in reece thread post 82 it may save more parts blowing and wasting money etc
          https://www.badcaps.net/forum/showth...=Ssi_400_14a01
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Re: 17pw26-4
            Probably is tbh Vince, mine was sending a crazy Vcc voltage to the fets causing them to blow when ever it did meaning the controller had failed intermittently.
            • x_orange90_x
              by x_orange90_x
              01-29-2025, 09:24 PM
            • MisterAIL
              PS5 digital / No Power / No Beep / Good power supply
              by MisterAIL
              Brought a non functionnal PS5. Apparently only a bad PSU...
              No beep, nothing.
              After some tests i found this :
              - PSU is fine (12 volts stable)
              - 12 volts line is shorted
              - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
              - By the way, nothing change. No signal, no power, no beep.
              Mesuring all rails with my workbench psu (12 volts input)
              - 0.00 amp drawing
              - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
              03-12-2024, 03:24 PM
            • Gentian
              APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
              by Gentian
              I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
              It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
              03-06-2023, 07:07 AM
            • valvashon
              Insignia NS-LCD19-09 (PS OK, Inverter problem?)
              by valvashon
              For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
              History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
              01-04-2024, 01:44 PM
            • Mcfeetroy
              Fishing bite alarm drains battery
              by Mcfeetroy
              Good day to all. The bite alarm drains 9-volt Krona batteries. Current consumption when switched on is about 50 mA. I wiped the board from oxides, I will attach a photo (on the board there is a j3y transistor and a 7533 stabilizer, the microcircuit is erased = (the 3.3-volt stabilizer heats up weakly. I replaced it, nothing changed. I unsoldered the microcircuit, the consumption disappeared. The resistance on the pins of the unsoldered microcircuit from the point clockwise is more than 2 megaohms, the 11th leg is presumably ground. I warmed up the microcircuit, the consumption does not change....
              08-01-2025, 03:52 AM
