PHILIPS (42PFL7623D/10) 2 BLINKING RED LED's
  • rigby
    • Feb 2016
    • 30
    • united kingdom
    #41
    Re: PHILIPS (42PFL7623D/10) 2 BLINKING RED LED's
    Originally posted by budm
    I download that service manual (Q529.1E), it does not match what you have at all.
    What is the P/N as printed on the barcode sticker on your power supply board?
    Thanks bud m it is PNE-M5 94v -0
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      #42
      I cant see any matches regarding that number can you take a good picture of the white sticker thanks
        That is not right, I can see 310432?????????
        • rigby
          • Feb 2016
          • 30
          • united kingdom
          #44
          Apologies Budm. It is the following
          HJ 908.29A.A 0132917
          s 310432 852763 W908FZ
          Cheers
          • rigby
            • Feb 2016
            • 30
            • united kingdom
            #45
            Hi again . Any advice on what to check next ? Thanks
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              #46
              Ive tried to search all the usually places for a schematic for the power supply all the numbers you have gave so far i dont get any luck on finding one, can you take a really good picture of the power supply so when we zoom in on it we can read the board markings etc, failing that its up to you if you want to board swop ie a power supply or a mainboard just make sure they have a good return policy if there bad on arrival.
              • rigby
                • Feb 2016
                • 30
                • united kingdom
                #47
                Thanks , I've been searching allover and all that I can find is foreignforum pages and no schematics, anyway I'm using a new Samsung led now but I may try swapping the psu at some stage in the next few weeks.
                If I find a fix ill update the thread then.
                Thanks to all who have helped to find a solution anyway .
                All the best .
                • rakiman
                  • Nov 2015
                  • 6
                  • turkey
                  #48
                  This topic was opened a long time ago, I am writing this in case it might be useful for a friend. I have been dealing with the same problem for days, these models give the LED bounce error 2 times when there is no speaker connected. Please connect a speaker. Or, to perform the operation with the lid open, connect a 4.7ohm resistor to the speaker outputs, the system will perceive these resistors as speakers, so the device will not give this error.
                  • nomoresonys
                    • 12283
                    • U.S.
                    #49
                    Not even standby voltage, seems like it must have been a powerboard issue.
                    • Pipolups
                      Corsair K70 LUX RGB dying LEDs
                      by Pipolups
                      Hi there !
                      I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                      Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                      10-08-2024, 11:58 AM
                    • horus100
                      Toshiba Z30-A-197 toshiba switched off and 2 blinking leds
                      by horus100
                      Hi, I've a problem with my laptop toshiba Z30: do not swith on and thare are 2 blink leds, white and yellow, blinking 2 times each one. I have disconnected the battery, CMOS battery, and reset bios but no effect, the laptop remain still switched off. Do you have any suggestion? Thak you!
                      12-19-2022, 01:25 AM
                    • gkolio
                      Sony Bravia 55w905a - 4 Red LEDs Blinking then Pink Tint
                      by gkolio
                      Hi have problem with 4 reds blink take lot help that forum and tell me change led strips and all going very good tv alive now but in down left have pink tint little and see only in white pages what wrong doing?
                      12-01-2023, 09:09 PM
                    • JuanL
                      Dell Vostro 3590: LEDs blinking 1 white - 3 yellow
                      by JuanL
                      I can't get the laptop to start. When pressing on, the laptop stays with the LEDs blinking 1 white and 3 yellow.
                      According to google this is due to the RTC battery. It was on 2.9 VCD and I have changed it for a new one, but it remains the same.
                      I have removed the M.2 NVME disk, I have also changed from slot 1 to 2, the only 8 GB slot RAM module, but I can't get out of this point.
                      The motherboard is an LA-G717P
                      What else could it be?
                      Thanks for the help and Happy New Year.
                      01-10-2022, 12:54 AM
                    • HP32Sii
                      Philips 50PUS6262/12 (chassis TMP17.7E LA) no picture
                      by HP32Sii
                      This is my first post on this forum, and my first attempted repair of a modern flat-screen LCD-TV (though I have repaired a few LCD-monitors, all with Elco-problems (high ESR). I have repaired my fair share of TV-sets and VCRs in the past ('90s) and was fairly familiar with the different Philips chassis (KT-3M, K12, K2, K3, K7 are some that come to mind). So I have a fair bit of experience on old sets. Obviously, modern TV sets are quite a different cup of tea.... no HOT or flyback-transformer inside, for starters....
                      The set came into my possession by accident,...
                      02-26-2023, 10:00 AM
