Sony Bravia 55w905a - 4 Red LEDs Blinking then Pink Tint
  • gkolio
    • Jul 2023
    • 18
    • Greece
    Hi have problem with 4 reds blink take lot help that forum and tell me change led strips and all going very good tv alive now but in down left have pink tint little and see only in white pages what wrong doing?
  • gkolio
    • Jul 2023
    • 18
    • Greece
    • gkolio
      • Jul 2023
      • 18
      • Greece
      New led strips but problem with 4 reds blink gone
      • gkolio
        • Jul 2023
        • 18
        • Greece
        Hi all need check flex cable from t-con to panel? Need oped again panel or is bad leds buy? Thx for all
        • EazyBone
          • Jun 2023
          • 1360
          • United states
          So the TV works normal except for the tint? Did you own the TV before the problem?
          Maybe, and I'm guessing, while taking it apart you could of damaged one of the panel connections causing a pink color. Or potentially it could be the LEDs, did you test the color before putting back together? If they tested white when you put them in then it's probably not the LEDs in my opinion.
          But yes check the cables and look to see if any of the pins were damaged
          • gkolio
            • Jul 2023
            • 18
            • Greece
            Tnx for answer yes work good with good colors all tv the pink watch only in white background if put out the t-con flex the corect is see white color? So no need to put out panel for that test
            • gkolio
              • Jul 2023
              • 18
              • Greece
              That led is have blue color stupidity thinks Sony the go one phosphoreth filter and go white color like that
              • gkolio
                • Jul 2023
                • 18
                • Greece
                  Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook 1 Specification for Upgrade or Repair
                  This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) schematic. Our users...
                  09-06-2024, 09:30 PM
                • jimjoe123
                  LCD TV Green/Pink screen problem
                  by jimjoe123
                  I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                  Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                  Then each time...
                  02-23-2020, 01:29 AM
                • Pipolups
                  Corsair K70 LUX RGB dying LEDs
                  by Pipolups
                  Hi there !
                  I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                  Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                  10-08-2024, 11:58 AM
                • thuss
                  55as802b Pink tint
                  by thuss
                  Hi
                  I was after some advice. My mates panasonic 55AS802b has a pink tint to it especially noticeable on a white background.
                  We have ran the lcd pattern test and all the other colours are fine apart from the white which is pink.
                  My question is, can this be altered via the service menu through the whitebalance section r-gain g- gain etc?
                  Is it the lcd screen or the backlights going faulty?
                  from the service manual it states The test pattern is created by the circuit in LCD Panel.
                  In LCD Panel test mode, this test pattern...
                  11-04-2020, 05:57 PM
                • tombodude
                  Dell P2412h LED monitor shows pink tint in white screens
                  by tombodude
                  All the whites have a pink tint, tried all the obvious stuff, different cables, different pc's, etc. Took it apart, and the power board has cheap looking caps, but no bulging or any signs of going bad. Signal board has all small caps, all look ok, usually small ones not a problem. Tried deoxing all the connections.
                  I don't know enough to test, but I can solder great and have repaired a lot of monitors by recapping the power board (mostly) with good Panasonic caps and sometimes the signal board since I had it out.
                  I can go ahead and recap the power board, but don't...
                  01-24-2020, 08:50 AM
