Samsung UN46EH5000F no backlight
  • m4a2t0t
    • Mar 2013
    • 276
    Trying to figure out why the backlight went out. No visible bad caps or burning on power board. Shining light on panel I can see the menu.
    Read this post
    https://www.badcaps.net/forum/showthread.php?t=50471
    Everything looks the same but I will get pics if you want.
    Unplugged the cable from power board to main board.
    Voltage across main cap on power board - .115 V
    D1+ to chassis gnd = .001V - sometimes I see it jump to 1.7 and then back down.
    I can hear a light whining coming from the board.
    Where should I start?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Samsung UN46EH5000F no backlight
    Check output voltage going to backlights.
    • m4a2t0t
      • Mar 2013
      • 276
      All pins on CNL802 connector are below 1.0V, most are .3V to .6V
        Please upload pictures of YOUR boards, also what is the P/N of your POWER SUPPLY /LED driver board BN44-?????
        • m4a2t0t
          • Mar 2013
          • 276
          I'll upload some in a min.
          BN44-00667A
          • m4a2t0t
            • Mar 2013
            • 276
            any suggestions.
            Is there a way to test the backlight and make sure it didn't cause the problems with the power board.
            • CapLeaker
              Leaking Member
              • 8112
              Turn the TV on and check the BLon pin on the PSU (bottom left corner).
              • thoma
                • Sep 2012
                • 268
                • m4a2t0t
                  • Mar 2013
                  • 276
                  I assumed the top left pin was pin 1.
                  1-12.8
                  2-1.04
                  3-12.8
                  4-12.8
                  5-12.8
                  6-4.8
                  7-12.8
                  8-10-GND
                  11-5.2
                  12-5.2
                  13-5.2
                  14-3.4
                    Pin names for each pin?
                    • m4a2t0t
                      • Mar 2013
                      • 276
                      CN803 IP SMPS to /fro MAIN BOARD
                      1-B13V
                      2-PWM_DIMM
                      3-B13V
                      4-B13V
                      5-Vamp 13V
                      6-BLU On/Off
                      7-Vamp 13V
                      8-GND
                      9-GND
                      10-GND
                      11-B5V
                      12-A5V
                      13-B5V
                      14-Power On/Off
                      • m4a2t0t
                        • Mar 2013
                        • 276
                        Well, I am just going to order a new power board. Hopefully that is it
                          You have all the correct Voltages. I doubt it is the power supply board.
                          https://www.badcaps.net/forum/showth...ht=BN44-00667A
                          • ed123
                            • Oct 2012
                            • 24
                            Hi Bud,
                            I have the same TV and when I disconnect the main board the backlight turns on by itself.Does that mean the LED's are ok and the main boards the problem?
                            Ed
                            • dick_barton
                              • Aug 2015
                              • 6642
                              • Wales
                              If the backlights come on with the mainboard disconnect then it generally indicates a problem on the mainboard.
                              Can you list all the voltages as in post #11
                              • ed123
                                • Oct 2012
                                • 24
                                Thank you for the quick responce.I was following the procedure until I unpluged the main from the power board to check the voltage at the 450volt cap and it showed about 385v and i saw all the leds light up.So I'm hoping a 23$ board from eparts on ebay will do the trick.Most people with this TV are having LED backlight issues.But I can't imagine a bad LED would light up.
                                The other thing I failed to mention was when the main board is connected,I can turn the TV on it makes the samsung "jingle" the backlight is OFF but I can barely see the menu option.The other important thing I think is I cannot turn the tv off using the power switch.I have to pull the plug from the wall.
                                sounds like an unlikely defective main board doesnt it?
                                Ed
                                  "The other important thing I think is I cannot turn the tv off using the power switch.I have to pull the plug from the wall.
                                  sounds like an unlikely defective main board doesnt it?"
                                  Yes.
                                  • ed123
                                    • Oct 2012
                                    • 24
                                    Thank you both for the quick responses I'll post when the board come in.
                                    Bud,
                                    I might have lucked out on this one.It might be interesting to note that unplugging the main from the power supply made the LED light up,is that normal?
                                    Ed
                                      Bud,
                                      Ed
                                      Yes, that is normal, that is how you do the self test of the power supply and backlights.
                                      • ed123
                                        • Oct 2012
                                        • 24
                                        Well....I got the new main board in from electro parts and nothing.The TV turns on when it's plugged in and no backlight and I cannot turn it off by the remote or the power switch.I called e-parts back and will try the power supply.But still when the main is unplugged the backlights all turn on.
                                        • C152Heavy
                                          by C152Heavy
                                          Summary for TL-DR readers:
                                          • VCC pin (18) of PFC...
                                          01-11-2023, 02:53 PM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • ermals
                                          Samsung UN55H8000AF - No Picture, Working Backlight, Replaced T-Con Board
                                          by ermals
                                          Hi all!
                                          I've recently run into an issue with my Samsung UN55H8000AF LED TV displaying no image. I've done quite a bit of research in terms of what could be wrong with it. Below are the steps I've taken prior to reaching out here for some assistance:
                                          1. I've tried replacing the T-Con board (BN95-01594A), twice and have still experienced the same issue with all the boards I've tested with.
                                          2. I've tried to remove one side of the ribbon cable that goes from the T-Con board to the panel and still not getting any image on left or right side.
                                          3. I've checked voltages...
                                          08-01-2022, 10:35 AM
                                          09-07-2024, 05:50 AM
