Samsung UN46EH5000F no backlight
  • ed123
    • Oct 2012
    • 24
    Re: Samsung UN46EH5000F no backlight
    Got a second main board from another vendor selling new boards and now the back light turns on very dim but uniformly dim all over the back through the tabs on the back of the TV I can barely see anything.If I unplug the main full brightness.Could it be the LED's?
      That means your new main board is keeping the backlights level low. You need to check the dimming control line.
      BTW, do you see pictures on the screen?
      • ed123
        • Oct 2012
        • 24
        Hi Bud
        Yes, I am able to see the menu options and tried turning up+down the backlight and if it made any difference at all it was hard to tell.The vendor hot price said it sounded like a bad eprom and has already sent out a replacement board N/C.
          Sounds like you are having bad luck getting good working board even though the sellers always say they are tested good working board which I doubt that they actually test them due to the fact that you have to have the TV that is made for the board.
          • ed123
            • Oct 2012
            • 24
            It's bad backlights! I just removed the screen and 12 out of 44 are lighting up.
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • C152Heavy
              Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
              by C152Heavy
              Summary for TL-DR readers:
              • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
              • Have obtained Samsung schematic & service documents - Can upload if helpful.
              • Have read ALL applicable threads
              • C1818 and CP820 replaced as low hanging fruit
              • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
              • VCC pin (18) of PFC...
              01-11-2023, 02:53 PM
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
            • ermals
              Samsung UN55H8000AF - No Picture, Working Backlight, Replaced T-Con Board
              by ermals
              Hi all!
              I've recently run into an issue with my Samsung UN55H8000AF LED TV displaying no image. I've done quite a bit of research in terms of what could be wrong with it. Below are the steps I've taken prior to reaching out here for some assistance:
              1. I've tried replacing the T-Con board (BN95-01594A), twice and have still experienced the same issue with all the boards I've tested with.
              2. I've tried to remove one side of the ribbon cable that goes from the T-Con board to the panel and still not getting any image on left or right side.
              3. I've checked voltages...
              08-01-2022, 10:35 AM
              09-07-2024, 05:50 AM
