Panasonic TC-P42S30 - Would someone mind helping me confirm SN?
  • Malachi
    • Dec 2015
    • 1077
    • Usa
    Re: Panasonic TC-P42S30 - Would someone mind helping me confirm SN?
    Ok, that's not who I used. Thanks.
    • tw2005
      • Oct 2011
      • 6458
      Originally posted by RCA2000
      TW_-you seem to be very knowledgeable on PDP sets...So is it NOT advisable to buy boards form a broken screen plasma set ?
      WIll it hurt MORE than the Y-buffers--I KNOW from the sound of a busted panel--is sounds like it is HARD on them...the loud "buzz" they make... WIll the Y-sustains (or sc board) get whacked ALSO? How about the Z_(or called SS or X in some sets ) ALSO get killed in a busted panel?
      Hard to generalise so I can only comment on experience and that being predominantly Panny PDP.
      Buying any board used is a risk in the beginning for it means the TV is unsalvageable in the first place and that generally would be bad panel.
      I've purchased 2 complete board sets of the 2010 FHD series, both cracked panels so you know in that condition they were powered and that generally means the panel shorts.
      Both had shorted Sd boards but all else were good.
      Damaged in transit new TVs are going to be good(never powered)
      Defective panel but running shpuld be ok
      And then you have the rest from junked TVs and unless whoever sells them knows what they're doing and invests time checking, it will be a gamble .
      As a rule I make sure i use paypal and if DOA contact seller, if that goes belly up, paypal claim.
      have not lost a penny yet.
      • 850csi
        • Jan 2016
        • 23
        No problem. My big mistake was not using by credit card to pay for it. So no fraud protection.
        Still not getting any reply from this great business, so I'm back to searching on ebay for another SN board and hoping it doesn't arrive "pre-shorted"!
        • syaoran123
          • Jun 2014
          • 178
          Happened to me also when I bought a cracked screen TV, moved the SN across and then 7 blinks still. Better to repair your own SN board, change the screws and add heatsinks to prevent from happening again.
          The SN board from the cracked screen TV had a short circuit across C482 (one of the long capacitors). There is no repair kit for this kind of repair.
          • saxmonster
            • Apr 2016
            • 5
            I received an SN board off of ebay from a "non working tv with a cracked screened" and it did not work. Got a full refund and I sent it to
            PTS Electronics, Inc.
            http://www.ptselectronicsinc.com/
            they said they could repair it even if it is the IC buffers. I had 6 blinking lights. So we shall see. They just got it yesterday so they should start working on it soon. Will post back here with the details if anything goes wrong. I found them via this site so fingers crossed it works out.
            -Scott
            • saxmonster
              • Apr 2016
              • 5
              My original board was already worked on by my brother inlaw so thats why I didn't send that in. I knew the buffers where bad on that one, cause he changed the parts but when he started the tv up there were lines and he tried to fix the ribbon cables / lines on tv with it on. A big no no, hahahah
              • flocko
                • Nov 2012
                • 1121
                • uk
                #27
                If the panel ribbons were adjusted with the set powered on, the PDP will almost certainly be damaged and leave your set beyond repair
                • saxmonster
                  • Apr 2016
                  • 5
                  what is the PDP, The display panel? I guess its too late now that they received the board. If the SN board is unrepairable I will just take the tv to the recycle center now knowing this little fact.
                  • saxmonster
                    • Apr 2016
                    • 5
                    Well I got my SN board back and all is good. It's been on for a couple of hours now and working perfect!!!! I highly recommend PTS electronics inc to fix these boards. Cost $75 to fix it and a 6month warranty too!!!!!. I think I will put my non working one on ebay as is and try to get some of my shipping money back from when i sent to PTS. Don't use USPS box to ship it, it was so expensive around $18m highway rip off. Also PTS has free shipping through UPS back to you. Sent on friday got it on monday. Great company.
                    -Scott
                    • tw2005
                      • Oct 2011
                      • 6458
                      -Scott
                      Sounds good. If you consider what you'd have to pay a tech to diagnose, remove, install and warrant the repair, less than a $100 is still good or alternatively the price of a new TV.
                      Given how rare these would be , I've seen broken boards around $20-30 , would suit those who repair them for business.
                      • Electronic Handyman
                        • Apr 2016
                        • 58
                        I've used boards from busted screens like buffer boards y-sustain boards and other boards, it's only happened I believe once that a board didn't work.In my opinion if you consider what ppl are spending on these type of boards especially y-sustain boards and buffer boards buying a set with a busted panel usually is a lot cheaper.
                        O ne post mentions that some repair service on ebay ripped them off for their board as long as you don't wait longer then 45 days to complain to ebay and paypal usually you can get your money back but not sure how they handle property theft.I'd think that thy'd compare the value of a new functional board via ebay sellers etc to figure out what a non-functioning board would be worth. Note that if the ebayer doesn't have the funds in their account or get any cash in it ,the purchaser maybe out of pocket.You should at least put in a complaint and comments to try and prevent others from getting ripped off.
                        • 850csi
                          • Jan 2016
                          • 23
                          Ebay refused to do anything claiming that repair services aren't covered under any sort of buyer protection. Eventually they caught on to the scam and deactivated the seller's account but not before at least 4-5 of us got screwed.
                          I'm pursuing it now through my bank. Problem is even if I get the money back I still don't have a board. Anyone have a busted board they want to part with?
                          If only I had not been an idiot and just gone through PTS.
                          • Malachi
                            • Dec 2015
                            • 1077
                            • Usa
                            #33
                            I may have one soon.
                            • 850csi
                              • Jan 2016
                              • 23
                              Managed to get my hands on a new board that was purportedly a Panasonic repair... Fingers crossed. Haven't tried putting it in yet but there's no continuity across SN2 pins so that's a start!
                              I'm still terrified that there's something else going on with my TV (or with my installation) that will short a perfectly good SN board. As in here, where apparently SS was causing SN to fail: https://www.badcaps.net/forum/showthread.php?t=23815
                              An SS board is only $20 - worth getting a new one before testing the new SN board and possibly risking a short? I'm just not sure if last time out the board I used was fried when I got it or was shorted out inside my own TV.
                              • 850csi
                                • Jan 2016
                                • 23
                                Just to close the loop: I still have no idea if the SS board was actually at fault, but I replaced both the SN and SS boards and everything works great! So glad to have my tv back. Here's hoping it'll last another few years until OLEDs get reasonable.
                                • BigPete
                                  Panasonic Heatpump Dryer Repair
                                  by BigPete
                                  I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                                  The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                                  In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                                  Unfortunately the whole machine has to come apart to fix it.
                                  I have...
                                  11-01-2025, 06:40 PM
                                • Andre Gilbert
                                  by Andre Gilbert
                                  11-20-2024, 08:52 PM
                                • AquaMan Ua
                                  Problem with PANASONIC CF53 laptop after changing BIOS settings
                                  by AquaMan Ua
                                  Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                                  05-17-2025, 09:40 AM
                                • stecos
                                  Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                  by stecos
                                  Hi everyone!
                                  I happened several times, in the search for help from the web, to consult this very interesting forum.
                                  So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                                  Having said that I come to the gist of my post on the forum as the title suggests.
                                  For my passion for technology I'm now collecting several...
                                  11-28-2022, 11:39 AM
                                • H H
                                  3090 FE Part Confirm/Identification
                                  by H H
                                  I'm hoping someone could help me confirm if I have identified the following parts correctly.
                                  Apparently the DP cable became stuck inside the graphics card and was yanked out. This caused some sort of short which burned the DP contacts and blew some resistors and ferrite beads.
                                  The parts needing replacement are on the back of the board behind the HDMI input.
                                  I have identified the parts as the following:
                                  C6037: MLCC 0.1uf/16v(0402)x7R W05
                                  R6016: RES 499 OHM 1/16W (0402) 1%
                                  LB10911: Ferrite Bead (0402)...
                                  02-16-2025, 01:09 PM
