Samsung LN40B530p7 sound ok picture inop
  • MLOO55
    • Jan 2016
    • 14
    • Peru from a city named Jauja
    I Have a problem with this tv, it happens that when I turn on the picture is normal but after 10 sec it turns black but sound or other functions work fine.
    I checked all caps with an esr tester and a cap tester so no cap damage was found.
    The voltage at the two main filter are:
    tv on 380 volts tv off 290 volts.
    Checked for any other component damaged ,resistors,diodes,mosfet and at first sight found none.
    As you can see in the picture where the connector is I took the voltages when the tv is on is as follow:
    1 3.17 v 16 5.22 v
    2 2.59 v 17,18 0 v
    3 5.2 v 19 13 v
    4 , 5, 6 0 v 20 0 v
    7,8 13 v 21,22 13 v
    9,10,11,12 0 v 23 4.46v13,14,15 5.22v 24 0 v
    25 3.34
    26,27,28,29, 30 0v
    I have some doubt about the reading at pin 23 inverter on/off, is this voltage correct? Besides at pin 25 what signal is E-pwm? and finally at pin 27 I have all the time 0v.
    I will appreciatte your comments about this problem or could be the lamps or one of them?
    rgds
    mloo55
  • MLOO55
    • Jan 2016
    • 14
    Re: Samsung LN40B530p7 sound ok picture inop
    Copying again the reading of voltages at connector CN801:
    1 3.17
    2 2.59
    3 5.2
    4,5,6 0
    7,8 13
    9,10,11,12 0
    13,14,15,16 5.2
    17,18 0
    19 13
    20 0
    21,22 13
    23 4.46
    24 0
    25 3.34
    26,27,28,29,30 0
    At pin 27 DET_5v voltage is 0 v? is correct
    thanks
    mloo55
      Please put the names of each pin after the pin number so we can see what Voltages, signals are missing.
      • johnboy1313
        • Nov 2012
        • 1959
        It looks like this is PSU BN44-00264B, but I can't tell for sure. Check for cold solder joints/burn marks at the inverter transformers. It's also posible you have a bad CCFL, or more, inside the panel.
          Pictures are not well focused to read the board P/N, BN44-??????
          I suspect bad inverter transformer as well.
          • MLOO55
            • Jan 2016
            • 14
            Here are the name of each pin and voltage with tv on and effectively the board is BN44-0264B.
            1 3.17 ON/OFF
            2 2.59 H_sync
            3 5.2 5VSB
            4,5,6 0 GND
            7,8 13 13V
            9,10,11,12 0 GND
            13,14,15,16 5.2 5.3V
            17,18 0 GND
            19 13 13V(MAIN)
            20 0 GND
            21,22 13 13V(mAIN)
            23 4.46 INVERTER ON/OFF
            24 0 NC
            25 3.34 E_PWM
            26 0 GND
            27 0 DET_5V
            28,29,30 0 GND
            thanks for your help
            mloo55
              It has all the correct Voltages and signals, so did you look real close at the inverter transformers to see if one or more of them has a sign of over heated, you need to look at both sides of the board.
              You also need to check the resistance of the HIGH vOLTAGE Winding of the inverter transformers to see if one or more than one have bad readings.
              BN44-00264B
              https://www.badcaps.net/forum/showth...ht=bn44-00264b
              http://www.shopjimmy.com/qgah02095-i...ansformer.htm#
              http://www.shopjimmy.com/samsung-bn4...wer-supply.htm
              • orinoco8
                • Jan 2016
                • 26
                You may want to check INVERTER ON/OFF voltage before and after the 10-second shut-off of backlight.
                • POL UK
                  • Sep 2014
                  Renew all 1000uF SMD capaccitors in PSU. Best Reagards
                  • MLOO55
                    • Jan 2016
                    • 14
                    I checked all inverter transformer and no signos of spots por something like it, all hace the same resistance readings.
                    The voltage at the on/off inverter pin is the same all the time as the tv is connected to the outlet.
                    I resoldered several points but the problem continúe. By the way, I have not replaced any ñamp until this momento mayor you indicate the steps to reach the lamps forma this tv.
                    Mloo55
                    • johnboy1313
                      • Nov 2012
                      • 1959
                      I'm betting you have a bulb that is failing or has already failed. Open the panel and take a look.
                      • MLOO55
                        • Jan 2016
                        • 14
                        I need your help for this task, how to reach the lámps? I removed the back cover and found the two boards so can you letra me Know what is the next Step or Steps.
                        Rgds
                        Mloo55
                        • johnboy1313
                          • Nov 2012
                          • 1959
                          You'll need to remove the plastic frame from around the panel. This will expose a metal frame surrounding the screen. Remove all of the screws holding the metal frame on. Remove the metal frame. Carefully lift the screen and store it flat, away from any chances of being broken. You will then see another plastic frame that will need to be removed. Then remove all of the diffuser sheets. Keep them all in order. They need to go back in the way they came out. This will expose the lamps.
                          • MLOO55
                            • Jan 2016
                            • 14
                            John, it means i have to remove the black bezzel which in the front so i can reach the lamps by this side no from he back,is correcta?
                            • johnboy1313
                              • Nov 2012
                              • 1959
                              Correct, you'll have to go in from the front.
                              • MLOO55
                                • Jan 2016
                                • 14
                                John,
                                I disassembled the tv to reach the lamps, followed your instructions and found some of the lamps are worn out so I will buy them to replace . They are 35.5 inches long. Again thanks.
                                mloo55
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  By a smashed 40" version off ebay and salvage the lamps.
                                  • MLOO55
                                    • Jan 2016
                                    • 14
                                    Thanks Reecey, goog info
                                    • bold_fusion
                                      • Mar 2020
                                      • 5
                                      • United States of America
                                      Hi there,
                                      I have an identical initial symptom (sound ok picture blinking off/on). The issue goes away when I turn the Backlight all the way to 0/10, but every so often the Backlight setting seems to automatically "reset" to 10/10 :-\.
                                      Thanks to this thread and forum, and a pair of YouTube posts (big thanks to https://www.youtube.com/watch?v=Dh01ZepjDp0 and https://www.youtube.com/watch?v=PflyJ4H51Fg), I've heard 3 main possibilities for this type of symptom:
                                      1. Inverter board caps bad (e.g., bulging?)
                                      2. Inverter board transformers bad (e.g., burn marks?)
                                      3. Back-light CCFP lamps bad
                                      Re #1, I don't see any caps bulging, but should I nonetheless test all the ceramic and electrolytic caps on the board?
                                      Re: #2, I don't see any burn marks on the inverter transformers, but didn't check the bottom side of the board. With the board unplugged, should I measure the resistance across both the primary and secondary windings on each of the 4 CCFP-driving transformers, and could you say what a "health" value would be?
                                      Re: #3, the video https://www.youtube.com/watch?v=Dh01ZepjDp0 is for a slightly different board, but shows how the "primary" of the transformer driving a broken CCFP lamp can be "bypassed" so that the low-resistance lamp isn't driven any more. This would make that lamp dark, but at least it would mean that the display wasn't turning off and on repeatedly. (I would gladly take that solution for the moment, and figure out how to repair the screen later!). For the inverter board of this thread (BN44-00264B), would the above bypass be feasible as a short-term solution, or would that, ahem, be a bad idea?
                                        • 12276
                                        • U.S.
                                        That's a good video there, watch closely how he does the ground out test, if you do that and the tv stays on then you found the problem and the bypass will work.
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • jchang
                                          Samsung UN70NU6900F no picture and no sound
                                          by jchang
                                          Hi all
                                          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                          Symptom:
                                          No picture no sound.
                                          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                          No sound at all.
                                          What I tried:
                                          1. I tried unplugging the left or right ribbon...
                                          01-09-2023, 06:28 PM
                                        • Dodgethis
                                          Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                          by Dodgethis
                                          Hello all,
                                          This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                          09-11-2024, 07:39 AM
