LG 42LW450U, no picture
  • finntricky
    • Jan 2014
    • 449
    got hold of this 42 inch LG 42LW450U 3D LED tv today, now my problem is, i have sound and i have back lights, so the tv is working apart from the picture,
    touching the buttons do what there supposed to do, and the remote works as well, so im 80% sure its not the main board thats the problem, so maybe the T-CON, im getting 12v at both ends of the fuse on the T-CON,
    what do you guys think, i would love someone in the UK to say, i have a t-con you can try, as i dont fancy paying out for one, and then finding out its the main board, and there not cheap.
  • CapLeaker
    Leaking Member
    • 8158
    Re: LG 42LW450U, no picture
    To rule out the main board, get a oscilloscope and check the LVDS, while turning the menu on and off.
    Also plug in only one side of the ribbon cable between the TCON and the panel, then the other.
    • finntricky
      • Jan 2014
      • 449
      no scope, and good idea about ribbons, i can't believe i never even thought of trying that,
      i will try it later, and get back.
      • finntricky
        • Jan 2014
        • 449
        ok, tryed removing ribbons from screen to t-con one at a time and got half screen picture,
        the side that shows the picture is grainy, very close lines running down the screen, i have now been able to get some pics up of it,
        so looks like a T-CON is needed,, would you agree ?
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Bad Panel Fin
          • CapLeaker
            Leaking Member
            • 8158
            not good... lines on the black side = bad panel.
            • finntricky
              • Jan 2014
              • 449
              Originally posted by ReeceyBurger123
              Bad Panel Fin
              yep, agreed. down the dump with it tomorrow then
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                More crappy Lcd panels failing nothing new
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Dont forget to take the Leds you can reuse them.
                  • advant
                    by advant
                    02-03-2020, 12:25 AM
                  • Awsmessymail
                    Vizio E701i-A3 backlight only and now no backlight
                    by Awsmessymail
                    Hello all,
                    I’ve tried to repair TVs in the past with some luck. Toms repair manuals got taken down and now thats a bit harder.
                    I picked this TV up hoping for a quick fix. When the TV would power on, only the backlights would come on. The owner told me they heard loud screeching before it shut off. This alone makes me want to think the main board has an issue.
                    As I researched, I found the TCON/driver boards were an issue on this unit. I went in troubleshooting the TCON but found good voltages on the TCON. I followed shop jimmys guide to test the transistors and they seem okay....
                    02-13-2024, 11:04 PM
                  • maxim2511
                    LG 55EC930V OLED - swich on swich of no screen
                    by maxim2511
                    My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
                    Then I get an idea to take it apart and clean boards from dust.
                    In side of Tv was not so bad, I take compressed air in can, and gently blow up.
                    Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
                    05-14-2021, 02:21 AM
                  • x_orange90_x
                    TCL 50S535 bad tcon or panel issue?
                    by x_orange90_x
                    Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                    03-29-2025, 11:02 PM
                  • EazyBone
                    Sony XR-77A80J OLED 5 Blink
                    by EazyBone
                    Another eazybone post took on this OLED now.
                    Symptoms. Hit power, white light shows briefly and then 5 blink red code. TCON issue per chart on first picture.
                    I'm thinking I have a power board issue though, which is one of the options
                    Now to check pin voltages from PSU to main and PSU to tcon
                    Pic 2
                    1 tcon on 12 -- 0v (when I hit power this goes to 3.1 stays for short time and back to zero)
                    2 bl err -- 0.16
                    3 evdd on --0
                    4. Ac off det 3.187
                    5 power on -- 3.362 BUT fluctuating randomly to 3.352
                    6 stby...
                    10-24-2023, 09:09 PM
