LG 42PC3D control board issue
  • wolds
    • Dec 2015
    • 4
    I've been working through an issue with my 42"LG. The initial symptom was that I had lost the picture but still had sound. I jumped on this forum and with some searching it looked like a Y or ZSUS board issue. I found an open fuse on the YSUS board but all looked good on the ZSUS. My other observation was that I got a sag in Vs (168Vdc) just before shutdown. I checked the power supply outputs and all were spot on otherwise. I sent the suspect board to Coppell for repair, but after re installation the same symptom remained. At this point I ordered a ZSUS board from Coppell and a buffer board. So long story short after installing these components still have the same issue. So now I'm looking at the control board and have made a few observations. First, if I disconnect the input to the control board the set will remain on with a white screen and a normal Vs of 186Vdc (per sticker on chassis). Also I noticed that there are four LEDS marked D12 through 15. All are solid green except D15 which is not lit. Is this normal or am I looking at a bad board. Any input from you guys would be appreciated. Warren
  • wolds
    • Dec 2015
    • 4
    Re: LG 42PC3D control board issue
    Anyone have experience with this issue in particular normal state of LED's D11-15 on the control board? Thanks, Warren
    • sordids999
      • May 2013
      • 2161
      Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
      • wolds
        • Dec 2015
        • 4
        Will do. Thanks
        • Soulzink
          Samsug washing machine. Power supply DC41-00189a board issue
          by Soulzink
          I am trying to fix a samsung washinmachine power supply main board.
          I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
          Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
          The power supply board reference is the following: DC41-00189a
          I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
          04-19-2025, 06:26 AM
        • Asraf Atb
          by Asraf Atb
          01-27-2025, 05:02 PM
        • Stephen
          A2991 Logic Board issue, 20volts 0 amps help!
          by Stephen
          Customer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...
          09-10-2025, 03:16 PM
        • Stephen
          A2991 logic board issue, 20volts 0 amps help!
          by Stephen
          09-10-2025, 03:15 PM
