I've been working through an issue with my 42"LG. The initial symptom was that I had lost the picture but still had sound. I jumped on this forum and with some searching it looked like a Y or ZSUS board issue. I found an open fuse on the YSUS board but all looked good on the ZSUS. My other observation was that I got a sag in Vs (168Vdc) just before shutdown. I checked the power supply outputs and all were spot on otherwise. I sent the suspect board to Coppell for repair, but after re installation the same symptom remained. At this point I ordered a ZSUS board from Coppell and a buffer board. So long story short after installing these components still have the same issue. So now I'm looking at the control board and have made a few observations. First, if I disconnect the input to the control board the set will remain on with a white screen and a normal Vs of 186Vdc (per sticker on chassis). Also I noticed that there are four LEDS marked D12 through 15. All are solid green except D15 which is not lit. Is this normal or am I looking at a bad board. Any input from you guys would be appreciated. Warren
LG 42PC3D control board issue
by SoulzinkHi everyone,
I am trying to fix a samsung washinmachine power supply main board.
I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
The power supply board reference is the following: DC41-00189a
I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel... -
by Asraf AtbHi everyone,
Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....1 Photo -
by StephenCustomer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...
by StephenCustomer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...09-10-2025, 03:15 PM
Assuming...7 Photos - Loading...
