E480-B2
Double check screen with flashlight and image comes in perfectly. Plug in dvd player as well to double check sound, and sound is good.
24 volt going from PSB to LED driver board.
I order EEPROM from shop jimmy and replace it.
Tv now turns on no problem backlight is on customer picks up set.
2 weeks go by and customer says tv is doing the same thing again.
Shopjimmy says they will send another EEPROM complimentary just in case the chip actually failed.
I replace it again, but this time it doesn't fix the issue.
PSB is still giving off 24 volts to the LED driver board, but driver board sends out 0 volts to the backlight.
Backlight never comes on, not even a quick half second flash. Is it possible the main board could have an issue somewhere else?
Has anyone come into this issue before?
Main board part number: 55.76R01.A01
LED driver part number: 55.76N04.B01
http://www.shopjimmy.com/vizio-55-76...or-e480-b2.htm
http://www.shopjimmy.com/vizio-55-76...iver-board.htm
No pics but this set is one of those where half of the back doesn't come off kind of like the westinghouse, Emerson, and so on.
PS on the left LED driver in the middle connected to the PS with the metal pins. Then cables going to Main on the right side.
Sorry no pics. If needed ill post.
