RCA LED50B45RQ - No Power or Standby light
  • zdsh07p9
    • Nov 2013
    • 155
    Hey Guys, I am on here a lot and wanted to let you guys know what fixed my LED50B45RQ. Got it in with no standby light at all - had power on the power board. I ordered a main board from ebay and it turned the tv on but I got the wrong one. Anyways - there is a capacitor on the main board that is right next to a red plug coming from the 24v I believe - and I replaced that and BAM - Fixed! (1 of the 2 capacitors total on the board)
    Thanks for all the help you guys give me, I look to give back a little
    Z
  • shelby5041
    • Feb 2009
    • 1505
    • united states of america usa
    ive got same tv but i have no standby light..no pwr on...i checked the dc voltages on the ps and all are 0v
    even if the main board is bad the power supply at a minimum should have 5v standby correct?...im thinking ps is bad.
    • lotas
      • Jan 2016
      • 4859
      • Russia
      If the power supply is connected to a motherboard that has a short circuit on the 5v bus, then the power supply will go into protection and there will be nothing at the output, you need to disconnect the power supply from the motherboard and check whether the voltage is 5v.
      • shelby5041
        • Feb 2009
        • 1505
        hi i checked the ps with the main board disconnected from the ps
        • AleMonti
          LG 55EG910V - no power and no standby light
          by AleMonti
          I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
          I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
          The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
          After checking the basics I did the following:
          • I measured all voltages and as expected the only active supply is the 3.5V standby. It
          11-04-2024, 05:02 PM
        • SkishyIshy
          Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
          by SkishyIshy
          Hey All,
          I have a Sony 65x900f that I purchased cheap because of a no-power issue.
          I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
          I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
          03-17-2021, 11:44 AM
        • noinimod
          Sony 55X900E no standby light, no power. Replaced mainboard already
          by noinimod
          No standby red light, nothing
          This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
          Disconnected JK3 power board from main board, checked voltages on all the pin outs
          At a few pins I can see the power supply providing 19.5V to the main board
          Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
          LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard,...
          12-22-2021, 12:58 AM
        • lapfix
          HP OMEN NO power no light
          by lapfix
          HP OMEN : DAG35DMBAD0
          NO power ,no short ,no corrusion
          Consumption : when charger plg in = 0.004 amp
          Only 3/5 vl are present when charger connected..when i put my red probe at the coils of 3/5volts and power on with my power suplly it try to rise than 0v.
          when try to power on using power button i note this starnge value : 3v then 0.300v then 3v !
          No light at power button led
          All coils resistances :
          Pl 2001 =3v measured with kohm.
          pl 2004 = 5v measured with kohm
          pl 6001 = 49.7ohm
          pl 4012 = vccsa = 24.4 ohm
          pl 3001 =...
          11-03-2025, 07:48 AM
        • x_orange90_x
          Vizio E550i-A0 no power, no standby light
          by x_orange90_x
          I have a Vizio E550i-A0 that will not power on. It also does not display the standby light in the corner. I disconnected the main board cable to see if the backlights would light but they did not (maybe this is normal for this set?). I checked the voltages on the plug and they all read in mV or 0, so there's no voltage there. The fuses are ok, and the voltages of the 450v caps read about 160v. I see no visual damage on either the power supply or main board. I have read online that the main board is usually the culprit in this model, but not getting backlights with the main disconnected makes me...
          11-20-2023, 09:49 AM
