TCL TV Dead sort of ??
+ More Options
Posts
  • CraigR
    • Dec 2013
    • 959
    I have a TCL TV and from what I can find out I think it's a L40FHDF11TATBAA but not positive as the sticker on the back is missing. Anyway this TV came in dead totally but I found a bad mosfet and a bad diode so I changed those and now it still looks dead except there is a LED on the power board that gives 3 long flashes and one short over and over. The set still shows nothing on the front for signs of life. I have 365v at the big cap and I only have 3.5v standby otherwise no 24v or nothing at PS_ON or BL_ON. I was wondering if I ran a 1k resistor from the 3.5 to the ps_on and bl_on if it would force backlights on?? Not sure how to go about this one since I never heard of TCL and can't find any guides. The power board is 08-LS182C0-PW200AA Much appreciated for any advice.
    Re: TCL TV Dead sort of ??
    Are you sure you do not have PS-ON? You do have 365VDC between the two legs of the main filter cap, for you to have that boosted Voltage the main board must be sending out the PS-ON signal to turn on the PFC Voltage booster section. Please verify again.
    Unless the circuit uses Active LOW signal (LO = ON).
    Disconnect the cable between the power supply/inverter and the main board to see if you will still get 365VDC on the main filter cap.
    BTW, 365VDC is kind of low, I expect it to be closer to 400VDC.
    • CraigR
      • Dec 2013
      • 959
      Confirmed, no voltage at PS_ON then big cap drops to nothing with the wire unplugged.
      • CraigR
        • Dec 2013
        • 959
        Any other thoughts budm?
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          I see a chip on the mainboard that has a chunk blown out of it.
          It's at the middle of the left hand side of the picture, by the HDMI ports.
          Edit: Looks like there might be an 8 pin chip that is burnt as well, on the far right side of the image (on the mainboard pic). It has a little bump on it ... might just be dust or flux, but I just wanted to point that out.
          Muh-soggy-knee
          • CraigR
            • Dec 2013
            • 959
            Good eyes ben7 you are correct. Don't know why I did not see that, must be my old eyes.
            • Alastair E
              Chief Womble
              • Mar 2013
              • 1963
              • U.K.
              That chip with hole--looks to be HDMI Controller....
              Typical issue when people plug/unplug HDMI's when the things are powered up! HDMI ISNT HOT Plug/Play--No matter WHAT they say!
              Prob not worth sourcing/replacing the chip--there'll be other damage I guess too. New Mainboard time...
              TELEFIX
                http://www.shopjimmy.com/catalogsear...40FHDF11TATBAA
                • CraigR
                  • Dec 2013
                  • 959
                  Yep, out of stock and only 1 on ebay out of the country and the TV is not worth the repair so another one hits the scrap heap. Thanks for the help guys!! Always appreciated!
                  • ben7
                    Capaholic
                    • Jan 2011
                    • 4059
                    Sounds like poor design to me!
                    The HDMI spec actually says it is hot-pluggable...
                    So basically, if a device fails like that when hot-plugged, then it doesn't fully comply with HDMI specs...
                    Muh-soggy-knee
                    • double_DD
                      How can I be sure that my EC chip is dead?
                      by double_DD
                      As the title suggests, how can I be sure that my EC chip is really dead?
                      I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                      Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                      03-12-2025, 07:47 AM
                    • disorder
                      ps5 edm-033 dead after hdmi/usb ports destroyed
                      by disorder
                      hello guys,
                      i need help to repair a edm-033 ps2
                      history : as always hdmi port and usb ports destroyed after unplugged
                      after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                      so i changed it
                      now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                      but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                      i don't see any projection of liquid metal on pcb.
                      01-14-2025, 12:48 PM
                    • Beton
                      Finding a dead short component
                      by Beton
                      Hi guys!
                      I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                      So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                      I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                      I have a bench PSU and if I try to inject voltage the voltage...
                      12-10-2021, 01:05 PM
                    • zunasthegreat
                      Chieftec GPS-450-AA with dead 20N60C3
                      by zunasthegreat
                      Hello everyone hope all doing well!
                      I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                      09-01-2024, 07:12 PM
                    • FiguringITout
                      MSI Raider GE75 - Not posting, probable dead CPU
                      by FiguringITout
                      Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
                      Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
                      07-25-2024, 07:27 AM
