INSIGNIA NS-L47Q09-10A dropped now black screen
  • jason424
    • Dec 2015
    • 187
    I received a INSIGNIA NS-L47Q09-10A with no picture. It was dropped by the former owner. I get the light on the front to light up red when plugged in and turns blue when hitting the power button. No image at all when turn off the room lights and check the screen or check with flashlight.
    I have replaced a capacitor on my old Vizio 47" so I'm fairly familiar with that and testing fuses etc. but I don't know where to start testing on each board (or what each is called for that matter).
    Re: INSIGNIA NS-L47Q09-10A dropped now black screen
    Can you hear anything rolling around inside the LCD panel? It will not be easy to flip the 47 panel around to see if you may have broken lamp inside.
    Also look at the back side of the LCD panel in the dark room to see if you can see the backlights flash on for seconds or not.
    • jason424
      • Dec 2015
      • 187
      When I picked up the tv and brought it home I heard nothing moving or rattling around.
      And I didn't see any light looking at the back in a dark room besides the front red/blue and the red optical port light up.
      • jason424
        • Dec 2015
        • 187
        Also, here are the voltages for the CN903 plug when the TV is plugged in and turned on:
        on/off: 3.1
        DIM: 3.1
        12v: 0
        12v: 0
        GND: ground
        GND: ground
        GND: ground
        24v: 1.3
        24v: 1.3
        PS_ON: 4.0
        5v: 5.0
        5v: 5.0
        I would think the 12v's should have some voltage?!?
          • 31198
          check the power board for cracks around all the screwholes and for cracked soldering on everything large or heavy.
            Beside looking for cracks on the board (you should remove the board from the chassis for close inspection, you should also
            check the DCV between the two legs of the main filter caps to see what you have.
            • jason424
              • Dec 2015
              • 187
              Voltage with tv plugged in and on:
              C907: 171.2
              C908: 170.5
              I'll remove the board after work for closer inspection.
                The PFC Voltage booster (the DCV should be closed to 400VDC range) is not working, the 12V/24V SMPS runs on the boosted Voltage, so you need check that PFC section out first.
                • jason424
                  • Dec 2015
                  • 187
                  Can you expand on what the PFC section is and how to test please? Beyond knowing what fuses and capacitors are, I'm clueless.
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    Here's a thought why don't you unplug the inverter from the power supply and try to repower check boosted voltages then. I once had an instance where there was a cracked CCFL tube in a Samsung 40 inch that kept the boost circuit from powering up from a direct short
                      Looking at pic #1 on post 1, it looks like he has both POWER cables, lamps cables, etc to the inverter board disconnected. OP did not explain why they are like that.
                      • jason424
                        • Dec 2015
                        • 187
                        I had unplugged the inverter board cables as I was looking at that board for damage on the underside. I had plugged it back in completely before running voltage tests above.
                        And to verify, I had checked the voltage of the 2 large black caps (upper left of board) in my 2nd photo. I assumed these were the "main filter caps" that were referred to?
                        • jason424
                          • Dec 2015
                          • 187
                          That would mean to unplug the 2 connectors (in the upper right of pic 4) coming from the power supply board, correct? And the boosted voltages were what I checked at the 2 big black caps?
                            'And the boosted voltages were what I checked at the 2 big black caps?'
                            Yes, those two large black caps (they are connected in parallel) laying its side are the main filer caps which should have close to 400VDC when the TV is turned on, but the PFC is not working right now so you are seeing only 160~170VDC.
                            • jason424
                              • Dec 2015
                              • 187
                              I unplugged the 2 power connectors leading to the inverter board and the voltage tests the same at the 2 large caps.
                              I didn't see any cracks in the board or loose heavy parts where solder would have come free. I did notice some black stuff (like comes out of the top of caps) looking like it was coming out the green fuse(?) in the pic. I ohm'd it out and got 8.0 with it installed. Not sure if I should remove to test or what it should read.
                              • jason424
                                • Dec 2015
                                • 187
                                Oh and what's the best way to de-energize a board ⚡️
                                  • 31198
                                  that's flux or glue
                                    • 31198
                                    cut the power,
                                    and meter the large caps - the voltage should slowly drop till it's down to nothing.
                                    • jason424
                                      • Dec 2015
                                      • 187
                                      Is there any instruction that I can review on how to test the PFC section? I'd rather try to isolate part needed and replace than replace whole board.
                                        IC901 is the PFC Controller IC, you need to get the P/N so you can get the pinout to find out if you do have VCC feeding the IC or not, also look real close at that section for any damages.
                                        • HTR-Informatique
                                          by HTR-Informatique
                                          02-09-2025, 06:51 AM
                                        • David82827372
                                          Dropped MacBookPro 15” 2012 shows black screen
                                          by David82827372
                                          MacBookPro 2012 15” A1398.
                                          No visual damage was found.
                                          Mac was inside of suitcase and it was inside of a bag.
                                          Mac boots up,I can hear the chime,but the screen is totally black,not even “light” black. Caps lock light doesn't work.
                                          I tried SMC,PRAM reset, didn't work.
                                          Reconnecting screen display by unplugging those two things didn't work. I used this video
                                          Reconnecting battery didn't work.
                                          I also tried SMC,PRAM reset while the battery was disconnected and Mac was getting...
                                          01-12-2024, 08:16 AM
                                        • DaniK
                                          Acer Aspire E5-574-52RH - black screen
                                          by DaniK
                                          I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
                                          Laptop came in for a SSD upgrade, took everything apart to install the SSD.
                                          Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
                                          Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
                                          The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
                                          Symptoms are:
                                          - random black screen after displaying Acer logo...
                                          02-21-2024, 06:27 AM
                                        • turmix
                                          AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                                          by turmix
                                          Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                                          The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                                          At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                                          During another reassembly, I made a mistake, and...
                                          01-29-2024, 03:48 AM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
