Le32a553 Button Board Failure Help ?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Hello chaps, diagnosed a faulty button board in this tv. What could cause the button board to change channel, volume etc. Seen this before never been able to sort it. Any advise is appreciated thank you.
  • johnboy1313
    • Nov 2012
    • 1959
    Re: Le32a553 Button Board Failure Help ?
    Any pics of the dud board?
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      1.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        2.
          I would check the resistance between the terminals of the switches to see if it shows leakage resistance.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Sorry I forgot to put that, all buttons check fine its a stupid intermittent fault. I have seen switches like these go intermittent before this is going to be a pain lol. Thanks
              The bad one that I usually found will have leakage resistance.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Ok bud will check tomorrow. Cheers
                • flocko
                  • Nov 2012
                  • 1121
                  To rule in or out buttons being at fault. unplug them and use remote to operate set ,if problem stops after being unplugged then replace button board
                  • comptek
                    • Aug 2013
                    • 606
                    i have had this it was one of the switches the channel would change randomly
                    the inside of the button is a dome silver disc through use gets inverted slightly and after a while causes the problem swopped out switches all ok
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Cheers
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        All my buttons test fine no leakage so bit fussed on this lol
                        • comptek
                          • Aug 2013
                          • 606
                          check cables for chafing ?
                          signs of liquid ingress both sides of board ?
                          if you look at the switches edge on like left to right to see if any are slighty down the the others they do collapse and cause problems when warm
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            Im going to try heating them tomorrow, I have already cleaned them with switch cleaner. Will let you know how it goes
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              I fixed the Tv by replacing the button board for £5 as the buttons were 99p each so not worth it. New board in and all working
                              • comptek
                                • Aug 2013
                                • 606
                                well done good fix
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  Cheers bud
