Hello chaps, diagnosed a faulty button board in this tv. What could cause the button board to change channel, volume etc. Seen this before never been able to sort it. Any advise is appreciated thank you.
Le32a553 Button Board Failure Help ?
https://www.facebook.com/Telford-Tel...7894576335359/Tags: None -
https://www.facebook.com/Telford-Tel...7894576335359/Comment
Re: Le32a553 Button Board Failure Help ?
I would check the resistance between the terminals of the switches to see if it shows leakage resistance.Never stop learning
Sorry I forgot to put that, all buttons check fine its a stupid intermittent fault. I have seen switches like these go intermittent before this is going to be a pain lol. ThanksPlease Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
The bad one that I usually found will have leakage resistance.Never stop learning
Ok bud will check tomorrow. CheersPlease Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
i have had this it was one of the switches the channel would change randomly
the inside of the button is a dome silver disc through use gets inverted slightly and after a while causes the problem swopped out switches all okComment
All my buttons test fine no leakage so bit fussed on this lolPlease Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
check cables for chafing ?
signs of liquid ingress both sides of board ?
if you look at the switches edge on like left to right to see if any are slighty down the the others they do collapse and cause problems when warmComment
Im going to try heating them tomorrow, I have already cleaned them with switch cleaner. Will let you know how it goesPlease Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
I fixed the Tv by replacing the button board for £5 as the buttons were 99p each so not worth it. New board in and all workingPlease Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
Cheers budPlease Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
Assuming...7 Photos -
by ygorsanHi everyone,
🧩 Problem Summary:- The TV keeps scrolling through the menu or selecting items by itself.
- I removed the physical button board (the entire panel with power and volume buttons) and also disconnected the flat cable (CN202) from the main board.
- The remote control is not in use (batteries removed), and the TV still shows the same behavior.
- I
07-28-2025, 08:34 AM -
Hi.
Long shot but does anyone have a schematic & boardview for the audio board+power button on a Macbook A2179?
There is a shorted cap on mine and I need to know if I can safely remove it or whether I need to replace it and with what capacitor.
Many thanks. ...-
Channel: Schematic Requests ONLY!
08-21-2025, 02:38 PM -
by kodoxthe board (yes, just the motherboard & daughter board) came to my desk with shorted ITE8585E, after ordered a programmed ITE and placing it on motherboard it turned on immediately, using HDMI i confirm that the boot entering the bios since there is no bootable drive attached. then i turned off by unplugging the DC adapter, while preparing keyboard, mouse & some flashdrive to boot into.
after all plugged (including adapter) the board doesn't "auto turn on" like before, pressing power button with no change. without unplugging anything i'm checking voltages needed... - Loading...
