47LG50 Red light flashes continuous
  • Gootch46
    • Oct 2015
    • 57
    I got this tv from a friend to look at and was following a thread someone else had to similiar tv (blue ON light came on but dim), ended up needing a power board. Well I ordered new board and when I received new board I installed it and had picture and sound . Scrolled through the sources all good, I put the tv all together and plugged in for a final check and red light just flashes, no clicking noises Nothing. So I have it back apart and I have weird power readings my 24v readings to both inverters go from 21v to 23 to 24 then back to 21 then repeat again randomly like that even get same readings at test point on inverters. On plug from power board to main board I have 5.1v there steady on the 2-5v pins but on the bottom 16.5v pin I get 9v then 5 then 12 then 9 then 5 then 12 continuouslly like that . Could this be a bad power board , It was from a somewhat trusted seller. I even put old power board back in same symptom as before then reinstalled new board same readings. I had this tv for a little bit. a friends cottage tv and after you all helped me get my uncles going again (whew) I decided to go back to this one. Any help would be appreciated . Oh and the green led on Main board flashes every second on off on off
    Pin1-NC
    Pin Pwm-Dim=0
    Pin On/Off= 0
    Pin ACD=.4
    gnd=
    gnd=
    Pin 5v=5.1
    Pin 5v=5.1
    Pin gnd
    Pin12v=12.4 steady
    gnd=
    Pin 16.4v= 9v then 5v then 12v then 9 again
  • aaronwt6
    • Apr 2013
    • 855
    • US
    Re: 47LG50 Red light flashes continuous
    Unplug the inverter boards and check your 24V reading with those disconnected and the TV turned on. Inspect the capacitors on the inverter boards. They are prone to failure and can cause erratic readings on the 24V line like that.
    • Gootch46
      • Oct 2015
      • 57
      Yep tried that still erratic readings , the tv did turn on with new PB but not now lol Thanks for the attempt tho man
      • Gootch46
        • Oct 2015
        • 57
        **Update** I unplugged both inverter boards and fired this up and still get the 24v jumping around I even tested the 2 big caps at c621 and the voltage on those even spike then drop with everything unhooked, so my question would be is what little part on this board would cause this spiking in electricity? Any suggestion would be helpful. Thanks
        • theyankeemoto
          • Dec 2016
          • 3
          • usa
          did you fix this? i just found your post. i have same tv same issue. just replaced the power board too from ebay, yupp just when i hook it up, tv turns on great, but than shuts off with the red light blinking. was it your backlight inverter boards? thanks pal
          • Gootch46
            • Oct 2015
            • 57
            I actually shelved this tv tried a new mainboard but these days it seems ther boards you try off fleabay are usually bad . But I am going to pick this tv up again soon Keep in touch .Thanks
            • esqmooo
              HP Elitebook 850 G8 CAPS lock flashes 7 times and charging light always on
              by esqmooo
              I'm facing this issue since this morning. When I try to power it on, the CAPS lock light flashes 7 times (or 6 if not counting the first one when the power button is pressed). The charging light is always on as if the laptop was connected to the charger. The issues started gradually where it would flash the light but after trying multiple time it would power on. I tried to open it and I noticed one coil "1R0 2127" gets hot when the charger is connected. Note: the charging light directly comes on when the battery is connected or the charger is connected.
              03-07-2025, 05:55 AM
            • russpall
              LG 39ln540v - red light flashes twice, no power to LED driver?
              by russpall
              Hi there,
              I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
              The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
              08-27-2024, 01:07 PM
            • cajoeg
              Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
              by cajoeg
              Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
              The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
              02-10-2025, 04:01 PM
            • provider22
              samsung UA32d4OO RED LIGHT FLASHES 3 TIMES
              by provider22
              Today, 02:45 AM
            • ruletero
              HP Omen only do not turn on, only flashes white light
              by ruletero
              Hi everyone
              Please help me with this laptop
              HP Omen 15-dc0003la , MB DAG3DBMB8D0 REV. D
              It doesn't turn on, when I connect the charger with battery orange light appears on power jack and without battery white light appear, it is fine I think
              But if I press power button, power led flashes white once, only that, not consumes anything power, not start, nothing more.
              Bios was programmed with a working version, no changes.
              Voltages
              +3vS5 = 3v when I connect charger, next goes to 0 (I think is fine)...
              06-07-2023, 10:11 AM
